Discuss
oil spots on clothes
 in
Washer Repair
Sporatic spotting on clothes that does not wash out. I can only assume that the spots are oil. I have
Appliance Repair Forum > Appliance Repair Help > Washer Repair » oil spots on clothes
  #1 (permalink)
Old 12-23-2007, 07:34 AM
admoc admoc is offline
Junior Member
admoc is on a distinguished road
Default oil spots on clothes
Model Number: 23012101   Brand: Kenmore   Age: 1 - 5 years
Sporatic spotting on clothes that does not wash out. I can only assume that the spots are oil. I have checked the tub and found no residue. No dark stains inside washer however mutiple spots appear on clothing from time to time, not consistent. Any ideas??????
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-23-2007, 08:25 AM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
ADMOC by any chance are you using liquid fabric softener, if so try not using it for a while and see what happens. if this washer is the older GE washer then it could be the transmission..
__________________
  #3 (permalink)
Old 12-23-2007, 08:58 AM
Junior Member
Default
We do use liquid fabric softner in our Kenmore. We will try not using it for a few weeks and see if that corrects the problem. Thank you for your reply.
  #4 (permalink)
Old 12-23-2007, 02:20 PM
richappy richappy is offline
Senior Expert
APP Volunteer
richappy is a glorious beacon of light
Default
Pull agitator out and check for oil on the spindle. Some slight oil is normal, but if a lot, you will need a new spindle seal, will have to pull tranny to replace and clean agitator inside.
If your ist 3 numbers of model # are 110, these comments apply, if not please post these numbers.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
drippin wet clothes jim_c Washer Repair 6 12-20-2007 08:47 AM
Clothes are not dry buckeye Dryer Repair 0 12-03-2007 11:15 AM
Clothes Dryer dschieb@grm.net Dryer Repair 1 11-14-2007 06:05 PM
clothes washer Nickrodz Washer Repair 0 11-02-2007 03:04 PM
Dirty Clothes woodyguy Washer Repair 2 10-16-2007 02:27 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
