noticed was was still wet after cycle, ran thru spin cycle again. Next day washer overflowed so stood by while starting new load..would not stop filling water overflowed..advanced time, started agitating than would not go thru spin cycle...unplugged advanced to spin cycle plugged in and it spun...help!:confused:
In general if it will not stop filling the tub between the tub and water level switch is blocked. The switch is air pressure activated, and the pressure increases as the tub fills.
So check the tube, and if it is ok the next thing is to try replacing the water level switch. I assume the water will stop when you stop the machine.
