When I try to start a load, at any setting, my washer will not do a thing. Usually there is a beep when I press the start button, there is not one now. All of the green lights are working, but the washer isn't starting. Help!!:mad:
Remove the washer front panel. Locate the green signal LED on top of the motor, under the inverter plate. Start the washer as usual and watch the LED. Post the results.
