| » banging noise |
Model Number: 11024622200 Brand: Kenmore Age: 1 - 5 years
Help! Kenmore top load washer. Frequently tub is out of balance on high speed dry cycle. Tub hit side of cabinet. Does this with sm and lg loads. redistributing the load does not normally correct problem. Thinking of replacing counter balance or suspension springs.
Washer was moved on its side or back. Oil was found in vehicle when unloaded. Do not hear any other noises except banging of tub hitting cabinet. Comments would be most appreciated. Ads By Google Related Models Last edited by Tom Roberts : 11-28-2011 at 08:01 AM. |
You may have several problems. It sounds as though some oil has leaked out of your transmission, which will cause major problems in the future if it is not immediately replaced.
I would also change out the springs, they may have been damaged in the move.
__________________
Your skateboard under the tub is out of position, remove the outer cabinet and compare the left side to the right side, then just lift up the skateboard and reposition it.
__________________
| Display Modes | |
| Loud Banging noise on way down and up | chrisawol | Trash Compactor Repair | 4 | 10-29-2012 03:35 PM |
| Washer Leaking/Banging Noise | kdchase | Washer Repair | 1 | 04-10-2011 05:51 PM |
| Banging Noise and scraping Noise | Annelo | Washer Repair | 0 | 10-31-2010 04:22 PM |
| Banging noise | camlog | Refrigerator & Freezer Repair | 1 | 05-17-2010 08:16 AM |
| Washer makes a banging noise | homesbygreg@aol.com | Dryer Repair | 1 | 04-12-2010 05:08 PM |
