| » Maytag Washer Makes Loud Moaning Noise During Spin Cycle |
Model Number: LAT8706AAM Brand: Maytag Age: More than 10 years
Maytag Washer Makes Loud Moaning Noise During Spin Cycle.
On this model the spin bearing normally causes this. Most of the time the tub seal is leaking causing the spin bearing to go rust and be noisy. To confirm remove the front start the washer and watch for leaks where the transmission enters the tub. note that sometimes it will be a small leak that you wouldn’t notice maybe one or two drops a load.
Note that if you don’t see a leak it can also be the bearings in the pulley under the bottom or the pump. Clothes Washer Repair Guide |
| Display Modes | |
| Makes loud bearing noise in spin cycle | dwoutersz | Washer Repair | 2 | 07-15-2011 07:15 PM |
| Washer makes loud noise at end of spin cycle | HVAC pirate | Washer Repair | 1 | 02-24-2010 05:28 PM |
| GE Prodigy makes loud bearing noise on spin cycle | TimN | Washer Repair | 0 | 02-02-2010 03:02 PM |
| Maytag washer makes loud noise during agitation and spin | brokewasher | Washer Repair | 1 | 08-23-2009 06:41 AM |
| Washer makes a loud clicking noise on spin cycle | pattihanni | Washer Repair | 0 | 05-02-2009 09:40 AM |
