Discuss
Washer Wont Fill
 in
Washer Repair
Washer has worked fine for 3 yrs. It now starts to fill, then water shuts off. It seems to be
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer Wont Fill
  #1 (permalink)
Old 12-22-2007, 04:05 PM
Jarinbixler Jarinbixler is offline
Junior Member
Jarinbixler is on a distinguished road
Unhappy Washer Wont Fill
Model Number: SAWS800JQ2   Brand: Whirlpool   Age: 1 - 5 years
Washer has worked fine for 3 yrs. It now starts to fill, then water shuts off. It seems to be intermittent. What do you think?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-22-2007, 10:05 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
does it happen on cold or warm or hot or all settings ,on every cycle , on what water level . is it just dead after water stops coming in. does it reach water level chosen. any humming sound.? have you tried advancing timer manualy to see what happens ? need more info
__________________
  #3 (permalink)
Old 12-22-2007, 11:14 PM
Junior Member
Default Washer Wont Fill
It seems to happen with any temp setting, every cycle, and every water level. Water begins filling like normal and then stops. I do hear a slight humming sound after it stops, sounds electrical. I have tried advancing the timer once it stops filling but nothing happens. I hope this info helps. I look forward to hearing from you soon...
  #4 (permalink)
Old 12-23-2007, 06:01 AM
Senior Expert
APP Volunteer
Default
buy what your tellin me it could be motor or some thing jammed in pump, like sock. motor+pump are conn ected sometimes it may be timer .you woul have to remove fron cabinet to acess pump +motor .remove pump clips ,pull off pump . turn machine on if water is still in tub ,see if motor runs in agitation cycle .if it does problem may be pump .you would have to remove pump hoses to look in ports its best to shop vac water ou of tub +clamp off drain hose from tub to pump, i usually jump connection to lid switch to effect spin .being this is intermitant problem may still be motor or timer even if you get motor to run .you can remove motor +try on its own
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer will not fill roddude32 Washer Repair 3 12-11-2007 07:14 PM
Whirlpool washer wont fill with water. dfwhip Washer Repair 1 12-10-2007 06:16 PM
wont fill DB1 Dishwasher Repair 2 12-01-2007 05:19 AM
GE Washer Wont fill only on inital wash stage Chrislorl Washer Repair 0 11-20-2007 09:45 AM
Washer will not fill up pssndwy Washer Repair 1 10-24-2007 09:54 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
