Discuss
fills and drains fine but it doesnt wash or rinse
 in
Washer Repair
i just change the coupling and after puting it back together now doesnt want to wassh or rinse it will
Appliance Repair Forum > Appliance Repair Help > Washer Repair » fills and drains fine but it doesnt wash or rinse
  #1 (permalink)
Old 11-25-2011, 07:38 PM
Junior Member
Gerry21 is on a distinguished road
Post fills and drains fine but it doesnt wash or rinse
Model Number: 11092586210   Brand: Kenmore   Age: More than 10 years
i just change the coupling and after puting it back together now doesnt want to wassh or rinse it will spin to drain the water but it wont spin to wash any answers out there?
Related Models
Kenmore 11092586210 WASHER
Kenmore 11092586400 WASHER
Kenmore 11092586410 WASHER
Kenmore 11092587200 WASHER
Kenmore 11092587210 AUTOMATIC WASHER
Kenmore 11092587400 WASHER
Kenmore 11092587410 AUTOMATIC WASHER
Kenmore 11092588200 WASHER
Kenmore 11092588210 WASHER
Kenmore 11092588400 WASHER
Kenmore 11092588410 WASHER
Kenmore 11092590100 AUTOMATIC WASHER
Kenmore 11092590110 WASHER
Kenmore 11092590120 WASHER
Kenmore 11092590800 AUTOMATIC WASHER
Kenmore 11092590810 WASHER
Kenmore 11092590820 WASHER
Kenmore 11092591200 WASHER
Kenmore 11092591210 WASHER
Kenmore 11092591220 WASHER
Kenmore 11092591230 WASHER
Kenmore 11092591400 WASHER
Kenmore 11092591410 WASHER
Kenmore 11092591420 WASHER
Kenmore 11092591430 WASHER
Kenmore 11092592200 WASHER
Kenmore 11092592400 WASHER
Kenmore 11092593200 WASHER
Kenmore 11092593210 WASHER
Kenmore 11092593220 Residential Washers
Kenmore 11092593400 WASHER
Kenmore 11092593410 WASHER
Kenmore 11092593420 Residential Washers
Kenmore 11092595200 Residential Washers
Kenmore 11092595210 Residential Washers
Kenmore 11092595400 WASHER
Kenmore 11092595410 Residential Washers
Kenmore 11092595500 Residential Washers
Kenmore 11092595510 Residential Washers
Kenmore 11092596100 WASHER
Kenmore 11092597200 AUTOMATIC WASHER
Kenmore 11092597210 AUTOMATIC WASHER
Kenmore 11092597400 AUTOMATIC WASHER
Kenmore 11092597410 AUTOMATIC WASHER
Kenmore 11092598200 Residential Washers
Kenmore 11092598400 Residential Washers
Kenmore 11092599200 Residential Washers
Kenmore 11092599400 Residential Washers
Kenmore 11092599500 Residential Washers
Kenmore 11092822100 GAS DRYER
Kenmore 11092822101 GAS DRYER
Kenmore 11092822102 GAS DRYER
Kenmore 11092822103 RESIDENTIAL DRYER
Kenmore 11092824100 GAS DRYER
Kenmore 11092824101 GAS DRYER
Kenmore 11092824102 GAS DRYER
Kenmore 11092824103 RESIDENTIAL DRYER
Kenmore 11092826100 GAS DRYER
Kenmore 11092826101 GAS DRYER
Kenmore 11092826102 GAS DRYER
Kenmore 11092826103 RESIDENTIAL DRYER
Kenmore 11092832100 DRYER
Kenmore 11092834100 DRYER
Kenmore 11092836100 DRYER
Kenmore 11092962100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092962101 LAUNDRY SYSTEM
Kenmore 11092962102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092964100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092964101 LAUNDRY SYSTEM
Kenmore 11092964102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092966100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092966101 LAUNDRY SYSTEM
Kenmore 11092966102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092972100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092972101 LAUNDRY SYSTEM
Kenmore 11092972102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092974100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092974101 LAUNDRY SYSTEM
Kenmore 11092974102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11092976100 WASHER DRYER LAUNDRY SYSTEM
Kenmore 11092976101 LAUNDRY SYSTEM
Kenmore 11092976102 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094518200 COMPACT AUTOMATIC WASHER
Kenmore 11094518201 AUTOMATIC WASHER
Kenmore 11094518400 COMPACT AUTOMATIC WASHER
Kenmore 11094518401 AUTOMATIC WASHER
Kenmore 11094519100 WASHER
Kenmore 11094519800 WASHER
Kenmore 11094570100 COMPACT WASHER
Kenmore 11094570800 COMPACT WASHER
Kenmore 11094572200 COMPACT WASHER
Kenmore 11094572201 AUTOMATIC WASHER
Kenmore 11094572400 COMPACT WASHER
Kenmore 11094572401 AUTOMATIC WASHER
Kenmore 11094762300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094818200 AUTOMATIC WASHER
Kenmore 11094818400 AUTOMATIC WASHER
Kenmore 11094821300 GAS DRYER
Kenmore 11094821301 RESIDENTIAL DRYER
Kenmore 11094831300 GAS DRYER
Kenmore 11094831301 RESIDENTIAL DRYER
Kenmore 11094832200 GAS DRYER
Kenmore 11094832201 GAS DRYER
Kenmore 11094834200 GAS DRYER
Kenmore 11094834201 GAS DRYER
Kenmore 11094836200 GAS DRYER
Kenmore 11094836201 GAS DRYER
Kenmore 11094872200 COMPACT AUTOMATIC WASHER
Kenmore 11094872400 COMPACT AUTOMATIC WASHER
Kenmore 11094962300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094964300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094966300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094972300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094974300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11094976300 WASHER/DRYER LAUNDRY SYSTEM
Kenmore 11095081400 RESIDENTIAL DRYER
Kenmore 11095081401 DRYER
Kenmore 11095081402 RESIDENTIAL DRYER
Kenmore 11095087400 DRYER
Kenmore 11095087401 DRYER GAS
  #2 (permalink)
Old 11-26-2011, 07:24 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
I am not sure what you are saying, but if you are saying it fills, doesn't agitate, timer goes on to point where it drains and spins, then fills and doesn't agitate in the rinse cycle but drains and spins, then the problem is likely a transmission problem or something simple like the agitator dogs.
See if the agitator turns freely, or if it "catches". If it turns without catching check the dogs. If the agitator catches operate with the cabinet off and see if the motor is turning in the agitation cycle. If so the problem is likely the transmission.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
D/W fills, drains, doesn't wash B Miller Dishwasher Repair 0 08-23-2011 01:26 PM
Dishwasher will not wash, fills and drains, no wash hitchcow Dishwasher Repair 0 07-14-2009 06:41 AM
fills and drains but doesnt wash behrgood Dishwasher Repair 4 05-18-2009 05:45 AM
washer fills & drains at same time when gets to rinse cycle wheelsx5 Washer Repair 1 04-07-2009 12:59 PM
Dishwasher fills and drains and runs trough cycles but doesnt wash ryan6663 Dishwasher Repair 1 10-24-2007 04:11 PM
