Discuss
Patty M
 in
Washer Repair
Washer spins, but water is still in tub. Washed rug which lost some shag. Am sure problem is in water
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Patty M
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-22-2007, 04:44 AM
pmustard pmustard is offline
Junior Member
pmustard is on a distinguished road
Default Patty M
Model Number: FWS747RFS0   Brand: Frigidaire   Age: 5 - 10 years
Washer spins, but water is still in tub. Washed rug which lost some shag. Am sure problem is in water pump, but cannot figure out how to open pump to remove contents which are causing problem. Same problem happened a couple of months ago and repairman charged $120 to come out and remove shag from pump. Please help.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-22-2007, 05:42 AM
okbobcats okbobcats is offline
Senior Expert
APP Volunteer
okbobcats is on a distinguished road
Default pump
Well if you can lower your drain hose to get most of the water out of washer do so. Or bail it out. or you can cut off water to punch by pinching the hose.
you have to takr front panel off. to get to pump. pinch water hose to pump. then take hose off remove pump. clean pump and reinstalled.
  #3 (permalink)
Old 12-22-2007, 01:46 PM
Junior Member
Default
Washer is fixed - it was the hose going out of the water pump to the drain that was stopped up. I assumed it was the hose going into the water pump. THANKS FOR YOUR HELP!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
