Hello,
I have an Admiral washer that will not spin. We had an article of clothing get under the agitator and got stuck. I had to remove the agitator to free the piece of clothing. I re-assembled the washer and proceeded to see if the machine would complete a cycle. [LIST=1]
I loaded a very small load Set water level for a small load The water level filled to desired amount I used a clothes pin to depress the lid switch so I could watch The washer went through the proper steps: fill, wash When it reached the spin cycle it would not spin. The agitator would work, but no spin. During the spin cycle the water would drain[/LIST]Also of note: I tipped the washer up and the belt is intact and the motor turns. BUT the tub will not turn manually at all.
Any help or suggestions would be greatly appreciated.
