| » Leak in Tub of Front Load Waser |
Model Number: FWT647GHS0 Brand: Frigidaire Age: 5 - 10 years
My front load washer is leaking at the bottom of the tub at the bolts.
Try tightening each bolt, if any are stripped out, you will need a tinerman nut on the other end.
If it still leaks, you will need to install a new seal between the tub halves, sort of a big job. If so, go to www.applianceaid.com for info on this. Also, while apart, it would be a good idea to clean and rust proof the aluminum alloy spider supports.
__________________
| Display Modes | |
| Frigidaire Front Load New Door Lock | kcchadmac | Washer Repair | 1 | 12-16-2007 07:38 PM |
| Frigidaire Front Load Washer Won't Spin | bbemis | Washer Repair | 2 | 11-28-2007 08:46 AM |
| front load Door seal | pueblo | Washer Repair | 1 | 11-27-2007 04:08 PM |
| spin cycle on frigidaire front load | Mikki | Washer Repair | 2 | 10-08-2007 05:15 PM |
| GE Front Load Washer Won't Drain | scottbreen | Washer Repair | 2 | 10-06-2007 09:46 PM |
