Discuss
washer won't stop filling!!!!
 in
Washer Repair
The washer won't stop filling. I can turn it on, and manually start it, and when i push the
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer won't stop filling!!!!
  #1 (permalink)
Old 12-20-2007, 02:31 PM
dalejrmaniac dalejrmaniac is offline
Junior Member
dalejrmaniac is on a distinguished road
Default washer won't stop filling!!!!
Model Number: vbxr1090d5cc   Brand: Hotpoint   Age: 1 - 5 years
The washer won't stop filling. I can turn it on, and manually start it, and when i push the knob in it stops, but if I let it run, it will overfill and leak all over the floor. I switched the load size to medium, with the same problem, but when i put it to small, no water came out at all. Is there some type of sensor in the machine which determines the water level, or does the timer do it? If it is the timer, can i replace just taht part?
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-21-2007, 01:05 PM
Gene's Avatar
Gene Gene is online now
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is a bad water level switch (inside the control panel).
- The part number for the water level switch is AP2045895
Good luck.
__________________
Professional appliance repair in Los Angeles, California.
  #3 (permalink)
Old 12-21-2007, 07:32 PM
misterfixall misterfixall is offline
Senior Expert
APP Volunteer
misterfixall is on a distinguished road
Default
some times detergents can clog the pressure switch hose at air dome at side of outer tub at left side.
__________________
  #4 (permalink)
Old 12-26-2007, 09:22 AM
Fix it all Fix it all is offline
Junior Member
Fix it all is on a distinguished road
Default
I have a similar problem with our GE.Water only trickles in at best and continues to trickle even if the washer is off or unplugged. It also will not keep from spinning during the drain cycle and water keeps trickling in. As the tub starts to spin (full) water continues to trickle in and it overflows onto the floor. This is our landlords machine and I have fixed it and the dryer before. Any clue??
  #5 (permalink)
Old 12-26-2007, 12:03 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Most likely the problem with your washer is a bad water inlet valve.
In order to provide the most accurate advise I need the complete model number of the washer.
Happy New year!
__________________
  #6 (permalink)
Old 12-26-2007, 12:16 PM
Junior Member
Default
Gene,
Thanks for the reply! I have no idea what the correct names of parts are, but I am usually pretty good at troubleshooting (although this is not my forte') I took off the hoses and removed a blue module with screens and diaphrams. The screens were all but closed off due to crust build up. I rinsed and cleaned them and I'm going to try to install once again. Will this also fix the problem with the tub wanting to spin during the drain cycle???
Thanks again!!
Tom
  #7 (permalink)
Old 12-26-2007, 12:21 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The part which you removed is the water inlet valve.
I do not think the cleaning will do any good. The part has to be replaced.
If you need the right part number I still need the complete model number of the washer.
The inner tub should spin at this time.
__________________
  #8 (permalink)
Old 12-26-2007, 12:42 PM
Junior Member
Default
I hooked it all back up and turned the water back on. I now have no water coming in when there shouldn't be. I'll get everything ready for a test spin and let you know how it goes. I'll get the model # from the service sheet just in case. Thank so much!
Tom
  #9 (permalink)
Old 12-26-2007, 12:52 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The model number is on the name plate attached to the cabinet on the bottom left side.
__________________
  #10 (permalink)
Old 12-26-2007, 01:08 PM
Junior Member
Default
Everything seems to be fine except that it is rinsing in hot water instead of cold. Could this just be a mixed up wire?? I hooked everything back up the way that I took it off, but since we weren't getting hot water to start with It could have been wrong to start with.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore washer not filling Amysmom Washer Repair 2 11-18-2007 05:53 PM
washer won't stop filling mnestinger Washer Repair 1 11-14-2007 12:25 PM
Washer will not stop filling Mwaters583 Washer Repair 1 10-26-2007 10:59 AM
washer overflows,does not stop filling cherokeedave Washer Repair 4 10-16-2007 04:38 PM
washer not filling wannabe Washer Repair 7 08-28-2007 10:02 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
