Discuss
Maytag washer leaking only on delicate cycle
 in
Washer Repair
HELP! My 2 1/2 year old Maytag washer is leaking about 1/3 cup of water only when set on "Delicate
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag washer leaking only on delicate cycle
  #1 (permalink)
Old 06-06-2009, 06:58 PM
Junior Member
bsly58 is on a distinguished road
Default Maytag washer leaking only on delicate cycle
Model Number: MAV4755AWW   Brand: Maytag   Age: 1 - 5 years
HELP! My 2 1/2 year old Maytag washer is leaking about 1/3 cup of water only when set on "Delicate cycle" and "handwash". It does not matter what the water level is set on.
This just started happening. It seems to be leaking from somewhere under the washer.
Ads By Google
Related Models
Maytag MAV4755AWW WASHER-TOP LOADING
Maytag MAV4757AWW WASHER-TOP LOADING
Maytag MAV4758AWW WASHER-TOP LOADING
Maytag MAV5000AWQ WASHER, ATLANTIS
Maytag MAV5000AWW WASHER, ATLANTIS
Maytag MAV5057AWQ WASHER, ATLANTIS
Maytag MAV5057AWW WASHER, ATLANTIS
Maytag MAV551EEWW WASHER-TOP LOADING
Maytag MAV5758EWW WASHER-TOP LOADING
Maytag MAV5920AGW WASHER-TOP LOADING
Maytag MAV5920EWK WASHER-TOP LOADING
Maytag MAV5920EWW WASHER-TOP LOADING
Maytag MAV5960AWW WASHER, ATLANTIS
Maytag MAV6000AWQ WASHER, ATLANTIS
Maytag MAV6000AWW WASHER, ATLANTIS
Maytag MAV6057AWQ WASHER, ATLANTIS
Maytag MAV6057AWW WASHER, ATLANTIS
Maytag MAV6200AWQ WASHER, ATLANTIS
Maytag MAV6200AWW WASHER, ATLANTIS
Maytag MAV6250AWQ WASHER, ATLANTIS
Maytag MAV6250AWW WASHER, ATLANTIS
Maytag MAV6257AWQ WASHER, ATLANTIS
Maytag MAV6257AWW WASHER, ATLANTIS
Maytag MAV6260AWW WASHER, ATLANTIS
Admiral MAV6300AGW WASHER-TOP LOADING
Maytag MAV6300AWQ WASHER, ATLANTIS
Maytag MAV6300AWW WASHER, ATLANTIS
Admiral MAV6300BGW WASHER-TOP LOADING
Admiral MAV6300CGW WASHER-TOP LOADING
Maytag MAV6357AWW WASHER, ATLANTIS
Maytag MAV6358AWW WASHER, ATLANTIS
Maytag MAV6451AGW WASHER, ATLANTIS
Maytag MAV6451AWQ WASHER, ATLANTIS
Maytag MAV6451AWW WASHER, ATLANTIS
Maytag MAV6457AWW WASHER, ATLANTIS
Maytag MAV6458AWW WASHER, ATLANTIS
Maytag MAV6548AWQ WASHER, ATLANTIS
Maytag MAV6548AWW WASHER, ATLANTIS
Maytag MAV6601AWQ WASHER, ATLANTIS
Maytag MAV6601AWW WASHER, ATLANTIS
Maytag MAV6650AWW WASHER, ATLANTIS
Maytag MAV7000AWQ WASHER, ATLANTIS
Maytag MAV7000AWW WASHER, ATLANTIS
Maytag MAV7057AWQ WASHER, ATLANTIS
Maytag MAV7057AWW WASHER, ATLANTIS
Maytag MAV7200AWQ WASHER, ATLANTIS
Maytag MAV7200AWW WASHER, ATLANTIS
Maytag MAV7257AWQ WASHER, ATLANTIS
Maytag MAV7257AWW WASHER, ATLANTIS
Maytag MAV7258AWQ WASHER, ATLANTIS
Maytag MAV7258AWW WASHER, ATLANTIS
Maytag MAV7260AWW WASHER, ATLANTIS
Maytag MAV7260BWW WASHER, ATLANTIS
Maytag MAV7357AWQ WASHER, ATLANTIS
Maytag MAV7357AWW WASHER, ATLANTIS
Maytag MAV7358AWQ WASHER, ATLANTIS
Maytag MAV7358AWW WASHER, ATLANTIS
Maytag MAV7450AWQ WASHER, ATLANTIS
Maytag MAV7450AWW WASHER, ATLANTIS
Maytag MAV7501EWW WASHER, ATLANTIS
Maytag MAV7504EWW WASHER, ATLANTIS
Maytag MAV7550AWQ WASHER, ATLANTIS
Maytag MAV7550AWW WASHER, ATLANTIS
Maytag MAV7551AWQ WASHER, ATLANTIS
Maytag MAV7551AWW WASHER, ATLANTIS
Maytag MAV7557EWQ WASHER, ATLANTIS
Maytag MAV7557EWW WASHER, ATLANTIS
Maytag MAV7580EWQ WASHER, ATLANTIS
Maytag MAV7580EWW WASHER, ATLANTIS
Admiral MAV7600ACQ WASHER-TOP LOADING
Admiral MAV7600AGW WASHER-TOP LOADING
Maytag MAV7600AWQ WASHER, ATLANTIS
Maytag MAV7600AWW WASHER, ATLANTIS
Admiral MAV7600BGW WASHER-TOP LOADING
Admiral MAV7600CGW WASHER-TOP LOADING
Maytag MAV7650AWQ WASHER, ATLANTIS
Maytag MAV7650AWW WASHER, ATLANTIS
Maytag MAV7657EWQ WASHER, ATLANTIS
Maytag MAV7657EWW WASHER, ATLANTIS
Maytag MAV7700AWQ WASHER, ATLANTIS
Maytag MAV7700AWW WASHER, ATLANTIS
Admiral MAV7750AGW WASHER-TOP LOADING
Admiral MAV7750BGW WASHER-TOP LOADING
Admiral MAV7750CGW WASHER-TOP LOADING
Maytag MAV7757AWQ WASHER, ATLANTIS
Maytag MAV7757AWW WASHER, ATLANTIS
Maytag MAV8000AWQ WASHER, ATLANTIS
Maytag MAV8000AWW WASHER, ATLANTIS
Maytag MAV8057AWQ WASHER, ATLANTIS
Maytag MAV8057AWW WASHER, ATLANTIS
Maytag MAV8260AWQ WASHER, ATLANTIS
Maytag MAV8260AWW WASHER, ATLANTIS
Maytag MAV8500AWQ WASHER, ATLANTIS
Maytag MAV8500AWW WASHER, ATLANTIS
Maytag MAV8551AWQ WASHER, ATLANTIS
Maytag MAV8551AWW WASHER, ATLANTIS
Maytag MAV8557AWQ WASHER, ATLANTIS
Maytag MAV8557AWW WASHER, ATLANTIS
Maytag MAV8600AWQ WASHER, ATLANTIS
Maytag MAV8600AWW WASHER, ATLANTIS
Maytag MAV8601AWQ WASHER, ATLANTIS
Maytag MAV8601AWW WASHER, ATLANTIS
Maytag MAV8757AWQ WASHER, ATLANTIS
Maytag MAV8757AWW WASHER, ATLANTIS
Maytag MAV9501EWQ WASHER, ATLANTIS
Maytag MAV9501EWW WASHER, ATLANTIS
Maytag MAV9504EWQ WASHER, ATLANTIS
Maytag MAV9504EWW WASHER, ATLANTIS
Maytag MAV9557EWQ WASHER, ATLANTIS
Maytag MAV9557EWW WASHER, ATLANTIS
Maytag MAV9600EWQ WASHER, ATLANTIS
Maytag MAV9600EWW WASHER, ATLANTIS
Maytag MAV9657EWQ WASHER, ATLANTIS
Maytag MAV9657EWW WASHER, ATLANTIS
Maytag MAV9750AGW WASHER, ATLANTIS
Maytag MAV9750AWQ WASHER, ATLANTIS
Maytag MAV9750AWW WASHER, ATLANTIS
Maytag MAVT236AWW WASHER-TOP LOADING
Maytag MAVT346AWW WASHER-TOP LOADING
Maytag MAVT446AWW WASHER-TOP LOADING
  #2 (permalink)
Old 06-07-2009, 01:43 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Well this is not supposed to happen. It's supposed to leak in all cycles, or not leak in any cycles.
Here's what you need to do. You want to operate the machine with the front panel off and observe and find the leak. To do this, use a screw driver or putty knife to release the clips holding the top to the base by inserting the tool in the crevice between the top and the base at the front, releasing the clips. These clips are near but not at the outer edge.
You can then take off the front panel by undoing two screws that hold it in. Then start the washer in the delicate cycle and observe it filling, agitating and draining. You will see the leak.
Good luck, and let us know what you find out.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Duet leaking on delicate cycle sbrock Washer Repair 4 02-07-2010 04:58 PM
Maytag works only in Delicate cycle dbest51@yahoo.com Washer Repair 3 09-30-2009 06:16 PM
Maytag top loading washer leaking in spin cycle from bottom kleve Washer Repair 3 07-23-2009 11:12 AM
Maytag washer completes delicate cycle only WSR Washer Repair 1 05-12-2009 01:36 PM
Maytag washer completes delicate cycle only. rsimms Washer Repair 8 11-22-2008 12:36 PM
