Discuss
GE Profile Washer Does Not Spin with Heavy Load
 in
Washer Repair
Washer fills, agitates, drains, but does not spin when the load is more than a couple t-shirts. The only previous
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE Profile Washer Does Not Spin with Heavy Load
  #1 (permalink)
Old 11-21-2011, 06:12 PM
Junior Member
dumblineman is on a distinguished road
Default GE Profile Washer Does Not Spin with Heavy Load
Model Number: WNSR3120W0AA   Brand: GE   Age: More than 10 years
The only previous problem was that it was overly loud during the spin cycle.
The only thing I've tried is cleaning out the pressure tube, but no dice so far.
Ads By Google
Related Models
General Electric WNSR3120W0AA Washer
General Electric WNSR3120W0WW Washer
General Electric WNSR3120W1AA Washer
General Electric WNSR3120W1WW Washer
General Electric WNSR4100Y1AA Washer
General Electric WNSR4100Y1WW Washer
General Electric WNXR2100T2AA Washer
General Electric WNXR2100T2WW Washer
General Electric WNXR2100T3AA Washer
General Electric WNXR2100T3WW Washer
General Electric WNXR2100T5AA Washer
General Electric WNXR2100T5WW Washer
General Electric WNXR2100T6AA Washer
General Electric WNXR2100T6WW Washer
General Electric WNXR2100T8AA Washer
General Electric WNXR2100T8WW Washer
General Electric WNXR2100TAAA Washer
General Electric WNXR2100TAWW Washer
General Electric WNXR2100TBAA Washer
General Electric WNXR2100TBWW Washer
General Electric WP71X23 Zoneline
General Electric WP71X26 Zoneline
General Electric WP71X4 Zoneline
General Electric WPGT9350C0PL Washer
General Electric WPGT9350C0WW Washer
General Electric WPGT9360C0PL Washer
General Electric WPGT9360C0WW Washer
General Electric WPGT9360E0PL Washer
General Electric WPGT9360E0WW Washer
General Electric WPRB8050D0CC Washer
General Electric WPRB8050D0WW Washer
General Electric WPRB8050D1CC Washer
General Electric WPRB8050D1WW Washer
General Electric WPRB9110D0CC Washer
General Electric WPRB9110D0WW Washer
General Electric WPRB9110D1CC Washer
General Electric WPRB9110D1WW Washer
General Electric WPRB9220C0CC Washer
General Electric WPRB9220C0WW Washer
General Electric WPRB9220C1CC Washer
General Electric WPRB9220C1WW Washer
General Electric WPRB9220D0CC Washer
General Electric WPRB9220D0WW Washer
General Electric WPRB9220D1CC Washer
General Electric WPRB9220D1WW Washer
General Electric WPRB9220DCCC Washer
General Electric WPRB9220DCWW Washer
General Electric WPRB9250C0CC Washer
General Electric WPRB9250C0WW Washer
General Electric WPRB9250D0CC Washer
General Electric WPRB9250D0WW Washer
General Electric WPRB9250D1CC Washer
General Electric WPRB9250D1WW Washer
General Electric WPRE5240D1WW Washer
General Electric WPRE6100G0WT Washer
General Electric WPRE6280D1WW Washer
General Electric WPRE6280DCWW Washer
General Electric WPRE8100G0WT Washer
General Electric WPSB8060B0CC Washer
General Electric WPSB8060B0WW Washer
General Electric WPSB8060B1CC Washer
General Electric WPSB8060B1WW Washer
General Electric WPSB8060B9CC Washer
General Electric WPSB8060B9WW Washer
General Electric WPSB9080B0CC Washer
General Electric WPSB9080B0WW Washer
General Electric WPSB9120B0CC Washer
General Electric WPSB9120B0WW Washer
General Electric WPSE3120Y1WW Washer
General Electric WPSE4200A0AA Washer
General Electric WPSE4200A0WW Washer
General Electric WPSE4270A0AA Washer
General Electric WPSE4270A0WW Washer
General Electric WPSE5290A0AA Washer
General Electric WPSE5290A0WW Washer
General Electric WPSE7001A0AA Washer
General Electric WPSE7001A0WW Washer
General Electric WPSE7002A0AA Washer
General Electric WPSE7002A0WW Washer
General Electric WPSE7003A0AA Washer
General Electric WPSE7003A0WW Washer
General Electric WPSE7003A1WW Washer
General Electric WPSE7003A9WW Washer
General Electric WPSE7003B9WW Washer
General Electric WPSF4170V0AA Washer
General Electric WPSF4170V0WW Washer
General Electric WPSF4170V1AA Washer
General Electric WPSF4170V1WW Washer
General Electric WPSF4170W0AA Washer
General Electric WPSF4170W0WW Washer
General Electric WPSF4170W1AA Washer
General Electric WPSF4170W1WW Washer
General Electric WPSF4170W2AA Washer
General Electric WPSF5170W0AA Washer
General Electric WPSF5170W0WW Washer
General Electric WPSF5170W1AA Washer
General Electric WPSF5170W1WW Washer
Whirlpool WPSHAW0
General Electric WPSL3120W0WW Washer
General Electric WPSL3120W2WW Washer
General Electric WPSP4170W0WW Washer
General Electric WPSP4170W1WW Washer
General Electric WPSQ3120T2AA Washer
General Electric WPSQ3120T2WW Washer
General Electric WPSQ3120T5AA Washer
General Electric WPSQ3120T5WW Washer
General Electric WPSQ3120T6AA Washer
General Electric WPSQ3120T6WW Washer
General Electric WPSQ3120T8AA Washer
General Electric WPSQ3120T8WW Washer
General Electric WPSQ3120T9AA Washer
General Electric WPSQ3120T9WW Washer
General Electric WPSQ3120TAAA Washer
General Electric WPSQ3120TAWW Washer
General Electric WPSQ4160T2AA Washer
General Electric WPSQ4160T2WW Washer
General Electric WPSQ4160T5AA Washer
General Electric WPSQ4160T5WW Washer
General Electric WPSQ4160T6AA Washer
General Electric WPSQ4160T6WW Washer
  #2 (permalink)
Old 11-22-2011, 09:15 AM
Senior Member
applianceman is on a distinguished road
Default
The belt may be worn out and you may have a bad clutch. Check the belt to see if it is worn out. Run the washer with your heavy load and look under the motor to see your clutch. If the motor is turning very fast and the clutch isn’t turning at all you have a bad clutch. Make sure the clip that should be on the bottom of the clutch is still there and if not replace the clip.
If it is overly loud during spin it could be that the tub seal is leaking. Start the washer into a wash cycle then watch for a leak where the tub meets the transmission. If you see any water even if it is only one drop during the wash cycle the tub seal is bad. A leaking tub seal can cause the belt to wear out and sometimes the clutch. If it gets to the point that it is noisy in spin (and the tub seal is leaking) you will have to replace the transmission to correct the problem (transmission comes with a tub seal). Hopefully it will just be the clutch or the belt but check for that leak because if it is leaking and you change the belt or clutch they may fail again.
If the tub seal isn't leaking all you will have to do is replace the belt, the clutch or both. If you are lucky all that is wrong is the little clip on the clutch.
This page will help in replacing the transmission should you need to replace it
GE Washer Disassembly Guide
  #3 (permalink)
Old 11-22-2011, 06:34 PM
Junior Member
Default
I didn't notice a leak while it was running, but there was some wetness underneath the washer itself.
The belt looks ok as far as I can tell, but then again what do I know.
Here are a couple of pics from underneath (attached).
  #4 (permalink)
Old 11-26-2011, 04:08 PM
Senior Member
Default
Sorry for the delay, days leading up to holidays are busy in appliance repair.
As far as the leak goes it could be as little as a few drops per load. There have been times were I watched them forever before it leaked. Lets hope not because this would be the worse case scenario.
It looks to be a lot of dust under the clutch, which is an indication that it is bad. But before you put a clutch on make sure the bottom pulley on the transmission will turn both ways by hand without a great deal of effort. When you turn it one way the whole transmission and tub should turn and the other way only the agitator will turn. If everything turns fine replace the clutch.
Note that I am assuming the motor is running since it works on small loads.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Drum doesn't spin on heavy load dcnguyen_98 Dryer Repair 0 08-17-2011 10:48 AM
Maytag washer doesn't spin out the clothes enough and they are heavy and wet. Help!!! adillon Dishwasher Repair 0 08-01-2010 09:51 AM
GE Washer stopped during heavy load rinse cycle Smita Washer Repair 0 07-18-2010 01:29 PM
GE Washer will not spin on heavy loads hmorton Washer Repair 1 05-14-2010 06:48 AM
wash machine will not spin with heavy load and makes a sound like a plane taking off lukasd Washer Repair 0 03-31-2009 04:33 PM
