Discuss
kenmore washer wont stop filling with water
 in
Washer Repair
hi, my kenmore washer will not stop filling with water on all water levels.if i move the timer dial manually
Appliance Repair Forum > Appliance Repair Help > Washer Repair » kenmore washer wont stop filling with water
  #1 (permalink)
Old 06-05-2009, 10:13 PM
Junior Member
jimbo0555 is on a distinguished road
Angry kenmore washer wont stop filling with water
Model Number: 11092389200   Brand: Kenmore   Age: 5 - 10 years
hi, my kenmore washer will not stop filling with water on all water levels.if i move the timer dial manually to the next stage ,nothing happens it only fills with water.no rinse or spin
Related Models
Kenmore 11092389200 WASHER
Kenmore 11092418100 AUTOMATIC WASHER
Kenmore 11092418600 AUTOMATIC WASHER
Kenmore 11092418800 AUTOMATIC WASHER
Kenmore 11092428100 AUTOMATIC WASHER
Kenmore 11092428600 AUTOMATIC WASHER
Kenmore 11092428800 AUTOMATIC WASHER
Kenmore 11092429100 AUTOMATIC WASHER
Kenmore 11092429600 AUTOMATIC WASHER
Kenmore 11092429800 AUTOMATIC WASHER
Kenmore 11092478100 AUTOMATIC WASHER
Kenmore 11092478600 AUTOMATIC WASHER
Kenmore 11092478800 AUTOMATIC WASHER
Kenmore 11092480200 WASHER
Kenmore 11092480400 WASHER
Kenmore 11092490100 Automatic Washer
Kenmore 11092490110 WASHER
Kenmore 11092490120 WASHER
Kenmore 11092491200 WASHER
Kenmore 11092491210 WASHER
Kenmore 11092491400 WASHER
Kenmore 11092491410 WASHER
Kenmore 11092529100 WASHER
Kenmore 11092529110 WASHER
Kenmore 11092529800 WASHER
Kenmore 11092529810 WASHER
Kenmore 11092560100 WASHER
Kenmore 11092560800 WASHER
Kenmore 11092561100 WASHER
Kenmore 11092561110 WASHER
Kenmore 11092561200 WASHER
Kenmore 11092561210 WASHER
Kenmore 11092561410 WASHER
Kenmore 11092561800 WASHER
Kenmore 11092561810 WASHER
Kenmore 11092562200 WASHER
Kenmore 1109257020 WASHER
Kenmore 11092570400 WASHER
Kenmore 11092571200 WASHER
Kenmore 11092571400 WASHER
Kenmore 11092572100 WASHER
Kenmore 11092572110 WASHER
Kenmore 11092572800 WASHER
Kenmore 11092572810 WASHER
Kenmore 11092573000 WASHER
Kenmore 11092573010 WASHER
Kenmore 11092573100 WASHER
Kenmore 11092573110 AUTOMATIC WASHER
Kenmore 11092573200 WASHER
Kenmore 11092573210 AUTOMATIC WASHER
Kenmore 11092573800 WASHER
Kenmore 11092573810 AUTOMATIC WASHER
Kenmore 11092573900 WASHER
Kenmore 11092573910 WASHER
Kenmore 11092574100 WASHER
Kenmore 11092574800 WASHER
Kenmore 11092575100 WASHER
Kenmore 11092575110 WASHER
Kenmore 11092577200 WASHER
Kenmore 11092577210 WASHER
Kenmore 11092577400 WASHER
Kenmore 11092577410 WASHER
Kenmore 11092578200 WASHER
Kenmore 11092578210 WASHER
Kenmore 11092578400 WASHER
Kenmore 11092578410 WASHER
Kenmore 11092579100 WASHER
Kenmore 11092579110 WASHER
Kenmore 11092579800 WASHER
Kenmore 11092579810 WASHER
Kenmore 11092580000 AUTOMATIC WASHER
Kenmore 11092580100 WASHER
Kenmore 11092580110 WASHER
Kenmore 11092580600 WASHER
Kenmore 11092580610 WASHER
Kenmore 11092580800 WASHER
Kenmore 11092580810 WASHER
Kenmore 11092580900 AUTOMATIC WASHER
Kenmore 11092581100 WASHER
Kenmore 11092581110 WASHER
Kenmore 11092581120 AUTOMATIC WASHER
Kenmore 11092581200 WASHER
Kenmore 11092581210 WASHER
Kenmore 11092581220 AUTOMATIC WASHER
Kenmore 11092581420 AUTOMATIC WASHER
Kenmore 11092581800 WASHER
Kenmore 11092581810 WASHER
Kenmore 11092581820 AUTOMATIC WASHER
Kenmore 11092582100 AUTOMATIC WASHER
Kenmore 11092582110 WASHER
Kenmore 11092582120 AUTOMATIC WASHER
Kenmore 11092582210 WASHER
Kenmore 11092582220 AUTOMATIC WASHER
Kenmore 11092582410 WASHER
Kenmore 11092582420 AUTOMATIC WASHER
Kenmore 11092582800 AUTOMATIC WASHER
Kenmore 11092582810 WASHER
Kenmore 11092582820 AUTOMATIC WASHER
Kenmore 11092583100 WASHER
Kenmore 11092583110 WASHER
Kenmore 11092583120 AUTOMATIC WASHER
Kenmore 11092583200 WASHER
Kenmore 11092583210 WASHER
Kenmore 11092583220 AUTOMATIC WASHER
Kenmore 11092583800 WASHER
Kenmore 11092583810 WASHER
Kenmore 11092583820 AUTOMATIC WASHER
Kenmore 11092584100 WASHER
Kenmore 11092584800 WASHER
Kenmore 11092585100 WASHER
Kenmore 11092585110 WASHER
Kenmore 11092585800 WASHER
Kenmore 11092585810 WASHER
Kenmore 11092586200 WASHER
Kenmore 11092586210 WASHER
Kenmore 11092586400 WASHER
Kenmore 11092586410 WASHER
Kenmore 11092587200 WASHER
Kenmore 11092587210 AUTOMATIC WASHER
Kenmore 11092587400 WASHER
  #2 (permalink)
Old 06-06-2009, 04:06 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
Hi Jimbo
If the water does not stop when you stop the machine you will have to replace the inlet valves. (or possibly the timer, but this is not likely)
If it does stop when you stop the machine, the problem is in your water level system.
1. Open up the cabinet and make certain the plastic tube running from the water level switch down along the side of the tub is not blocked and is properly connected.
If it is
2. Replace the water level switch.
Good luck and let us know how it turns out.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE washer wont stop filling up dmhm3268 Washer Repair 2 04-16-2010 07:16 AM
GE washer wont stop filling van213 Washer Repair 1 01-12-2010 02:31 PM
washer wont stop filling JOHNNYMAC Washer Repair 1 06-14-2009 05:36 PM
Kenmore washer wont stop filling with water wannabecoach1 Washer Repair 7 11-22-2008 01:42 PM
Washer wont stop filling/wont agitate khart26 Washer Repair 1 08-05-2008 11:58 AM
