Hoping someone might be able to help,
Currently have a Maytag LAT9400ABW Washer in our Rental house (I'd call landlords but their on holidays) which will not run into Spin Cycle.. Happened to be downstairs earlier when it stopped, moved the items around thinking it was off balance and still won't go. Managed to drain the water out but stumped as to what it could be.. managed to run a couple of loads earlier in the day without issues.
If you moved the timer and the machine drained, the timer may be the issue. If you had to drain the machine by hand and moving the timer will not cause it to run, check the lid switch.
