AppliancePartsPros.com
Appliance Repair Help
Washer Repair
Can someone please verify these motor test readings?
I tested the motor according to the repair manual and got these readings:
pins 1 to 5 high spd stator, normal = approx 0.2 ohm, actual = 0.8 pins 5 to 10 low spd stator, normal = approx 1.1 ohms, actual = 1.8 pins 6 to 7 protector, normal = approx 0.0 ohms, actual = 0.6 pins 3 to 4 tacho, normal = approx 68 ohms, actual = 68 pins 8 to 9 brusher, normal = approx 0.95 ohms, actual = 3.6
are these readings ok, are they just showing a little wear n tear, or is the motor shot?
many thanks & appreciation!
Washer Repair
