Discuss
Frigidaire still leaks
 in
Washer Repair
Can anyone help me before I turn my washer into a smoker !!! I have a frigidaire stackable dryer/washer, back
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Frigidaire still leaks
  #1 (permalink)
Old 06-04-2009, 12:29 PM
Junior Member
txaggie075 is on a distinguished road
Default Frigidaire still leaks
Model Number: FEX831FS0   Brand: Frigidaire   Age: 1 - 5 years
Can anyone help me before I turn my washer into a smoker !!! I have a frigidaire stackable dryer/washer, back in March I replaced a seal set which seemed to have fixed the leak but now the thing is leaking again. I rechecked the seals and there is not a problem with them am I missing another seal that might be bad? I do notice when it spins that it is making a high pitch squeal. Someone...anyone help....
Thanks Joe
Ads By Google
Related Models
Whirlpool FGP335EQ0
Whirlpool FGP335EW0
Whirlpool FGP335GN0
Whirlpool FGP335GN1
Whirlpool FGP335GQ0
Whirlpool FGP335GQ1
Whirlpool FGP335GW0
Whirlpool FGP335GW1
Whirlpool FGP335HN0
Whirlpool FGP335HQ0
Whirlpool FGP335HW0
Whirlpool FGP335VL0
Whirlpool FGP335VL1
Whirlpool FGP335VL2
Whirlpool FGP335VL3
Whirlpool FGP335VW0
Whirlpool FGP335VW1
Whirlpool FGP335VW2
Whirlpool FGP335VW3
Whirlpool FGP335YL0
Whirlpool FGP335YL1
Whirlpool FGP335YL2
Whirlpool FGP335YW0
Whirlpool FGP335YW1
Whirlpool FGP335YW2
Whirlpool FGP337GN0
Whirlpool FGP337GN1
Whirlpool FGP337GN5
Whirlpool FGP337GQ0
Whirlpool FGP337GQ1
Whirlpool FGP337GQ5
Whirlpool FGP337GW0
Whirlpool FGP337GW1
Whirlpool FGP337GW5
Whirlpool FGP337HN0
Whirlpool FGP337HQ0
Whirlpool FGP337HW0
Whirlpool FGP337KN0
Whirlpool FGP337KQ0
Whirlpool FGP337KW0
Whirlpool FGP337KW1 30" Gas Freestanding Standard Clean Range Electro
Whirlpool FGP345VL0
Whirlpool FGP345VL1
Whirlpool FGP345VL2
Whirlpool FGP345VW0
Whirlpool FGP345VW1
Whirlpool FGP345VW2
Whirlpool FGP345YL0
Whirlpool FGP345YW0
Whirlpool FGP355VL0
Whirlpool FGP355VL1
Whirlpool FGP355VL2
Whirlpool FGP355VL3
Whirlpool FGP355VW0
Whirlpool FGP355VW1
Whirlpool FGP355VW2
Whirlpool FGP355VW3
Whirlpool FGP355YL0
Whirlpool FGP355YW0
Whirlpool FGP357XL0
Whirlpool FGP357XW0
Whirlpool FGP357YL0
Whirlpool FGP357YL1
Whirlpool FGP357YL3
Whirlpool FGP357YW0
Whirlpool FGP357YW1
Whirlpool FGP357YW2
Whirlpool FGP357YW3
Frigidaire FGQ1442ES0 Frigidaire/dryer
Frigidaire FGQ332ES0 Frigidaire/gas Dryer
Frigidaire FGQB2152FE0 Frigidaire/dryer
Frigidaire FGQB4000FS0 Frigidaire/dryer
Frigidaire FGQBB30DS0 Frigidaire/dryer
Frigidaire FGR211AS0 Dryer - Frigidaire
Frigidaire FGR211AS1 Dryer - Frigidaire
Frigidaire FGR211AS2 Frigidaire/gas Dryer
Frigidaire FGR211AS3 Frigidaire/gas Dryer
Frigidaire FGR211AS4 Frigidaire/dryer
Frigidaire FGR211MAS0 Frigidaire/dryer
Frigidaire FGR221AS0 Dryer - Frigidaire
Frigidaire FGR231AS0 Dryer - Frigidaire
Frigidaire FGR231AS1 Dryer - Frigidaire
Frigidaire FGR231AS2 Frigidaire/dryer
Frigidaire FGR231AS3 Frigidaire/gas Dryer
Frigidaire FGR231AS4 Frigidaire/dryer
Frigidaire FGR231CAS4 Frigidaire/dryer
Frigidaire FGR311FS0 Frigidaire/dryer
Frigidaire FGR331AS0 Dryer - Frigidaire
Frigidaire FGR331AS1 Dryer - Frigidaire
Frigidaire FGR331KAS1 Frigidaire/gas Dryer
Frigidaire FGR341AC0 Frigidaire/dryer
Frigidaire FGR341AC1 Frigidaire/dryer
Frigidaire FGR341AS0 Dryer - Frigidaire
Frigidaire FGR341AS1 Dryer - Frigidaire
Frigidaire FGR641FS0 Frigidaire/dryer
Frigidaire FGR6600ES0 Frigidaire/dryer
Frigidaire FGR6600FS0 Frigidaire/dryer
Frigidaire FGRB5700DS0 Frigidaire/dryer
Frigidaire FGRB6600ES0 Frigidaire/dryer
Frigidaire FGRB6600FS0 Frigidaire/dryer
Frigidaire FGRB7800DS0 Frigidaire/dryer
Whirlpool FGS325RQ0 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ1 30" Gas Freestanding Self Clean Range
Whirlpool FGS325RQ2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD0 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD1 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD2 30" Gas Freestanding Self Clean Range
Whirlpool FGS326RD3 30" Gas Freestanding Self Clean Range
Whirlpool FGS335EN0
Whirlpool FGS335EQ0
Whirlpool FGS335EW0
Whirlpool FGS337GN0
Whirlpool FGS337GN1
Whirlpool FGS337GN5
Whirlpool FGS337GQ0
Whirlpool FGS337GQ1
Whirlpool FGS337GQ5
Whirlpool FGS337GQ6
Whirlpool FGS337GQ7
Whirlpool FGS337GW0
  #2 (permalink)
Old 06-05-2009, 03:30 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi Joe
Sorry your repair did not work, I know that job takes a lot of time and effort.
Leaks and noise are two of the more difficult problems to diagnose in a forum like this. I would take off the front of the washer and run it to see if you can visually locate the source of the leak and hear to area where the noise is coming from.
Good luck, and let us know what you find.
__________________
  #3 (permalink)
Old 06-07-2009, 03:29 AM
Junior Member
Default Leaky frigidaire....
Sidfink43....
I took the front panel off of the washer and filled it up with water, let it sit and stated to run the machine, the leak is coming from the are of the plastic tub splash where two phillips screws go. I have already replaced a set of seals once back in march, took those off and they looked okay but could they not be seated right on the transmission?? There is a small washer under there also. Any help is greatfully appreciated. Thanks.
Joe
  #4 (permalink)
Old 06-07-2009, 06:19 AM
Senior Expert
APP Volunteer
Default
Hi Joe
As you know water leaks can only come from the hoses bringing water into the machine, hoses taking water out and the center tub seal.
Sounds like your one leak may be coming from the hose assembly that brings water into the tub. I would replace that part, it is not expensive.
With respect to your still leaking tub seal since you just replaced it I would just pull it off, clean it and re-seat it.
Good luck and let us know how it turns out.
__________________
  #5 (permalink)
Old 06-09-2009, 07:06 AM
Junior Member
Default
other than the tub seal could there be a leak anywhere else underneath the tub? There are two phillips screws that screw into the tub splash, that's where i also see the leak. I'm going to replace the tub seal right now and see what happens.
Thanks for helping.
Joe
  #6 (permalink)
Old 06-09-2009, 07:14 AM
Senior Expert
APP Volunteer
Default
The only leak you can have underneath is from the discharge hoses and pump, which you should be able to see fairly easily.
I think when you fix your seal it will probably solve your underneath problem.
good luck and let us know how it turns out.
__________________
  #7 (permalink)
Old 06-09-2009, 11:00 AM
Junior Member
Default
Man i hope so....to get a repair person out just to look at my washer is $54.00, then parts and labor which is what i'm trying to avoid. but i did manage to get a replacement seal kit. I'll keep you informed.
Joe
  #8 (permalink)
Old 06-09-2009, 12:49 PM
Junior Member
Question
Just want to make sure that i'm putting the seal back the correct way, big seal goes on first, then smaller seal with the brass piece down...i'm second guessing myself,
  #9 (permalink)
Old 06-09-2009, 03:31 PM
Senior Expert
APP Volunteer
Default
That's right. Make sure the first piece is set down tight and that the brass piece is all around the second piece.
Hope this works. Again, I would operate the machine with the front panel off so you can see exactly what is happening. Sometimes with a small leak you will want to wrap a piece of paper towel around the fitting so you can be sure and see it, a lot times it is to small to view.
__________________
  #10 (permalink)
Old 06-28-2009, 06:41 AM
Junior Member
mikelee_slc is on a distinguished road
Default Frigidaire seal tub
Hey im having the same problem after replacing the Seal Tub kit on a stackable Frigidaire washer. When I look at the old seal tub kit there is a little bit of sticky stuff on the boot edge. I think maybe we need to add some grease to the Seal. Does anyone know if this is correct? If so how much grease should be used?
Mike Lee
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Frigidaire DishWasher leaks from bottom four2699 Dishwasher Repair 1 12-14-2009 06:34 AM
Frigidaire Multiple Water Leaks TCSRG0 Refrigerator & Freezer Repair 0 12-07-2009 09:41 AM
Gas leaks KGash Oven Repair (including Ranges and Cooktops) 0 12-01-2009 12:53 PM
frigidaire leaks water from underneath running or not! smsrobertks Dishwasher Repair 0 04-10-2009 09:13 AM
Frigidaire front loader door leaks tonim Washer Repair 4 03-30-2008 04:38 AM
