Discuss
Whirlpool washer
 in
Washer Repair
wanting to do a hot load of clothes. switch temp. control to hot and (no hot water) comes out. switch
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool washer
  #1 (permalink)
Old 06-04-2009, 10:56 AM
Junior Member
wfnelsoniii is on a distinguished road
Default Whirlpool washer
Model Number: WTW5700SW0   Brand: Whirlpool   Age: 1 - 5 years
wanting to do a hot load of clothes. switch temp. control to hot and (no hot water) comes out. switch control to cold and cold water comes out. I made sure both hoses were connected correctly (hot to hot) and (cold to cold). any solutions?
Thanks,
Bill
Ads By Google
Related Models
Whirlpool WTW5700SW0 Automatic Washer
Whirlpool WTW5790SQ0 Automatic Washer
Whirlpool WTW5790ST0 Automatic Washer
Whirlpool WTW5800SG0 Automatic Washer
Whirlpool WTW5800SW0 Automatic Washer
Whirlpool WTW5810SW0 Automatic Washer
Whirlpool WTW5820SW0 Automatic Washer
Whirlpool WTW5821SW0 Automatic Washer
Whirlpool WTW5830SW0 Automatic Washer
Whirlpool WTW5840SG0 Automatic Washer
Whirlpool WTW5840SW0 Automatic Washer
Whirlpool WTW5850SG0 Automatic Washer
Whirlpool WTW5850SW0 Automatic Washer
Whirlpool WTW5860SG0 Automatic Washer
Whirlpool WTW5860SW0 Automatic Washer
Whirlpool WTW5900SB0 Automatic Washer
Whirlpool WTW5900SW0 Automatic Washer
Whirlpool WTW5900TB0 Automatic Washer
Whirlpool WTW5900TW0 Automatic Washer
Whirlpool WTW6200SW0 Automatic Washer
Whirlpool WTW6200SW1 Automatic Washer
Whirlpool WTW6200SW2 Automatic Washer
Whirlpool WTW6200SW3 Automatic Washer
Whirlpool WTW6300SB0 Automatic Washer
Whirlpool WTW6300SB1 Automatic Washer
Whirlpool WTW6300SB2 Automatic Washer
Whirlpool WTW6300SG0 Automatic Washer
Whirlpool WTW6300SG1 Automatic Washer
Whirlpool WTW6300SG2 Automatic Washer
Whirlpool WTW6300SW0 Automatic Washer
Whirlpool WTW6300SW1 Automatic Washer
Whirlpool WTW6300SW2 Automatic Washer
Whirlpool WTW6400SW0 Automatic Washer
Whirlpool WTW6400SW1 Automatic Washer
Whirlpool WTW6400SW2 Automatic Washer
Whirlpool WTW6400SW3 Automatic Washer
Whirlpool WTW6600SB0 Automatic Washer
Whirlpool WTW6600SB1 Automatic Washer
Whirlpool WTW6600SB2 Automatic Washer
Whirlpool WTW6600SB3 Automatic Washer
Whirlpool WTW6600SG0 Automatic Washer
Whirlpool WTW6600SG1 Automatic Washer
Whirlpool WTW6600SG2 Automatic Washer
Whirlpool WTW6600SG3 Automatic Washer
Whirlpool WTW6600SW0 Automatic Washer
Whirlpool WTW6600SW1 Automatic Washer
Whirlpool WTW6600SW2 Automatic Washer
Whirlpool WTW6600SW3 Automatic Washer
Whirlpool WTW6700TW0 Automatic Washer
Bosch WTZ1170
Bosch WTZ1210
Whirlpool WU0800B
Whirlpool WU0800XX0
Whirlpool WU0800XX1
Maytag WU100 Dishwasher - Undercounter
Maytag WU1000 Dishwasher - Undercounter
Whirlpool WU1000X0
Whirlpool WU1000X1
Whirlpool WU1000X4
Whirlpool WU1000X5
Whirlpool WU1000X6
Whirlpool WU1000X7
Whirlpool WU1000X8
Whirlpool WU1000Y0
Whirlpool WU1000Y1
Maytag WU1004 Dishwasher - Undercounter
Maytag WU1005 Dishwasher - Undercounter
Maytag WU101 Dishwasher - Undercounter
Maytag WU103 Dishwasher - Undercounter
Maytag WU104 Dishwasher - Undercounter
Maytag WU180 Dishwasher - Undercounter
Whirlpool WU1800XX0
Frigidaire WU180T1BLACK Wwh(v5) / 18 " Dishwasher
Frigidaire WU180TF1 Wwh(v3) / 18 " Dishwasher
Frigidaire WU180TH1 Wwh(v2) / 18 " Dishwasher
Frigidaire WU180TR1 Wwh(v1) / 18 " Dishwasher
Frigidaire WU180TV1 Wwh(v4) / 18 " Dishwasher
Frigidaire WU180TW1 Wwh(v6) / 18 " Dishwasher
Maytag WU181 Dishwasher - Undercounter
Maytag WU200 Dishwasher - Undercounter
Maytag WU201 Dishwasher - Undercounter
Maytag WU202 Dishwasher - Undercounter
Maytag WU203 Dishwasher - Undercounter
Maytag WU204 Dishwasher - Undercounter
Maytag WU282 Dishwasher - Undercounter
Maytag WU284 Dishwasher - Undercounter
Maytag WU285 Dishwasher - Undercounter
Maytag WU300 Dishwasher - Undercounter
Whirlpool WU3000V0
Whirlpool WU3000V1
Whirlpool WU3000V2
Whirlpool WU3000V3
Whirlpool WU3000X0
Whirlpool WU3000X1
Whirlpool WU3000X2
Whirlpool WU3000X3
Whirlpool WU3000X4
Whirlpool WU3000X5
Whirlpool WU3000X6
Whirlpool WU3000Y0
Whirlpool WU3000Y1
Whirlpool WU3006V0
Whirlpool WU3006V1
Whirlpool WU3006V2
Whirlpool WU3006V3
Whirlpool WU3006X0
Whirlpool WU3006X1
Whirlpool WU3006X2
Whirlpool WU3006X3
Whirlpool WU3006X4
Whirlpool WU3006X5
Whirlpool WU3006X6
Whirlpool WU3006Y0
Whirlpool WU3006Y1
Maytag WU301 Dishwasher - Undercounter
Maytag WU302 Dishwasher - Undercounter
Maytag WU303 Dishwasher - Undercounter
Maytag WU304 Dishwasher - Undercounter
Whirlpool WU3050Y0
Whirlpool WU3050Y1
  #2 (permalink)
Old 06-05-2009, 03:18 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi
Well, here's the way I would start. This is in order of ease, not necessarily likelihood of the problem, which is probably the timer. Of course, that would be the most expensive repair.
1. check the hot water line to make certain there is nothing clogging the screens in the inlet valve and the hose coming from the hot water tap.
2. operate it on warm wash, see if you get warm water or just cold water. If you get warm water the problem is probably your timer and youwill have to replace it.
3. Take off the console and inspect your connections on wires from the temp selection switch to the timer. Checks the wires for any break, exposed wire etc, and clean the contacts, reconnect and try it again.
4. Take off the cabinet and check to see if you have 120 v coming to the hot water connection at the inlet valves. If you do, the problem is with the inlet valves and it needs to be replaced.
If none of these solve your problem, then the problem is probably with the temp selection switch or the timer. I think the timer is the more likely culprit, although the tem selection switch is the less expensive of the two. At this point you will just have to try one or the other.
Good luck and let us know what you find out.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
WhirlPool Washer CCS FIXER Washer Repair 16 03-02-2010 01:56 PM
whirlpool washer fordpickupgirl Washer Repair 3 01-09-2010 12:48 PM
whirlpool washer MOODMUFFIN Washer Repair 1 06-16-2009 04:21 PM
whirlpool washer rsr13@hughes.net Washer Repair 1 05-23-2009 06:31 PM
whirlpool washer leepahl Washer Repair 1 11-03-2008 09:47 AM
