Discuss
Maytag Atlantis washer out of balance
 in
Washer Repair
The washer has developed an issue that seems to be uncontrollable. When first purchased if the wash load was not
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Maytag Atlantis washer out of balance
  #1 (permalink)
Old 11-19-2011, 06:56 PM
Junior Member
F150 is on a distinguished road
Default Maytag Atlantis washer out of balance
Model Number: MAV9600EWQ   Brand: Maytag   Age: 5 - 10 years
The washer has developed an issue that seems to be uncontrollable. When first purchased if the wash load was not evenly distributed the spin cycle speed would be reduced to compensate for the out of balance condition.
Now the machine will spool up during the spin cycle and if the wash load is not evenly distributed the drum bangs the cabinet with such force the washer "walks" across the floor. No more gradual increase in speed.
I have checked to ensure the machine is level side to side and front to back a number of times with no avail.
Any ideas?
Related Models
Maytag MAV9600EWQ WASHER, ATLANTIS
Maytag MAV9600EWW WASHER, ATLANTIS
Maytag MAV9657EWQ WASHER, ATLANTIS
Maytag MAV9657EWW WASHER, ATLANTIS
Maytag MAV9750AGW WASHER, ATLANTIS
Maytag MAV9750AWQ WASHER, ATLANTIS
Maytag MAV9750AWW WASHER, ATLANTIS
Maytag MAVT236AWW WASHER-TOP LOADING
Maytag MAVT346AWW WASHER-TOP LOADING
Maytag MAVT446AWW WASHER-TOP LOADING
Maytag MAVT546EWW WASHER-TOP LOADING
Maytag MAVT634AWW WASHER, ATLANTIS
Maytag MAVT734EWW WASHER, ATLANTIS
Maytag MAVT754EWW WASHER, ATLANTIS
Maytag MAVT834AWQ WASHER, ATLANTIS
Maytag MAVT834AWW WASHER, ATLANTIS
Whirlpool MB1110SLQ MICROWAVE OVEN 1.1 CUBIC FOOT
Admiral MB1927PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB1927PEHW REF - MAYTAG INT'L BOT MOUNT
Admiral MB2216PUAW REF - BOTTOM MOUNTS
Maytag MB2216PUAW11 REFRIGERATOR
Maytag MB2216PUAW2 REFRIGERATOR
Admiral MB2227PEHB REF - MAYTAG INT'L BOT MOUNT
Admiral MB2227PEHW REF - MAYTAG INT'L BOT MOUNT
Thermador MB245 MICROWAVE
General Electric MB536BB1 Electric range
Whirlpool MB7120XYB0 Microwaves*
Whirlpool MB7120XYB1 Microwaves*
General Electric MB757WB1 Electric range
Maytag MBB1952GRQ REF - BOTTOM MOUNTS
Maytag MBB1952GRW REF - BOTTOM MOUNTS
Maytag MBB1952HEB REF - BOTTOM MOUNTS
Maytag MBB1952HEB1 REFRIGERATOR
Maytag MBB1952HEB10 REFRIGERATOR
Maytag MBB1952HEQ REF - BOTTOM MOUNTS
Maytag MBB1952HEW REF - BOTTOM MOUNTS
Maytag MBB1952HEW14 REFRIGERATOR
Maytag MBB1952HEW5 REFRIGERATOR
Maytag MBB1953WEB0 REFRIGERATOR
Maytag MBB1953WEB1 REFRIGERATOR
Maytag MBB1953WEB2 REFRIGERATOR
Maytag MBB1953WEW0 REFRIGERATOR
Maytag MBB1953WEW1 REFRIGERATOR
Maytag MBB1953WEW2 REFRIGERATOR
Maytag MBB1953XEB0 REFRIGERATOR
Maytag MBB1953XEW0 REFRIGERATOR
Maytag MBB1954GEB REF - BOTTOM MOUNTS
Maytag MBB1954GEQ REF - BOTTOM MOUNTS
Maytag MBB1954GES REF - BOTTOM MOUNTS
Maytag MBB1954GEW REF - BOTTOM MOUNTS
Maytag MBB1954HEW REF - BOTTOM MOUNTS
Maytag MBB1956GEB REF - BOTTOM MOUNTS
Maytag MBB1956GEQ REF - BOTTOM MOUNTS
Maytag MBB1956GES REF - BOTTOM MOUNTS
Maytag MBB1956GEW REF - BOTTOM MOUNTS
Maytag MBB1956HEB REF - BOTTOM MOUNTS
Maytag MBB1956HEB14 REFRIGERATOR
Maytag MBB1956HEQ REF - BOTTOM MOUNTS
Maytag MBB1956HES REF - BOTTOM MOUNTS
Maytag MBB1956HEW REF - BOTTOM MOUNTS
Maytag MBB1956HEW14 REFRIGERATOR
Maytag MBB1957VEB1 REFRIGERATOR
Maytag MBB1957VEB10 REFRIGERATOR
Maytag MBB1957VEB2 REFRIGERATOR
Maytag MBB1957VEW1 REFRIGERATOR
Maytag MBB1957VEW10 REFRIGERATOR
Maytag MBB1957VEW2 REFRIGERATOR
Maytag MBB1957WEB0 REFRIGERATOR
Maytag MBB1957WEB1 REFRIGERATOR
Maytag MBB1957WEW0 REFRIGERATOR
Maytag MBB1957WEW1 REFRIGERATOR
Maytag MBB2254GEB REF - BOTTOM MOUNTS
Maytag MBB2254GEQ REF - BOTTOM MOUNTS
Maytag MBB2254GES REF - BOTTOM MOUNTS
Maytag MBB2254GEW REF - BOTTOM MOUNTS
Maytag MBB2256GEB REF - BOTTOM MOUNTS
Maytag MBB2256GEQ REF - BOTTOM MOUNTS
Maytag MBB2256GES REF - BOTTOM MOUNTS
Maytag MBB2256GEW REF - BOTTOM MOUNTS
Maytag MBCM24FWBS00 WINE CELLAR
Maytag MBF1952VEW1 REFRIGERATOR
Maytag MBF1956HEB REF - BOTTOM MOUNTS
Maytag MBF1956HEQ REF - BOTTOM MOUNTS
Maytag MBF1956HES REF - BOTTOM MOUNTS
Maytag MBF1956HEW REF - BOTTOM MOUNTS
Maytag MBF1956KEB REF - BOTTOM MOUNTS
Maytag MBF1956KEB11 REFRIGERATOR
Maytag MBF1956KEB2 REFRIGERATOR
Maytag MBF1956KEB3 REFRIGERATOR
Maytag MBF1956KEB4 REFRIGERATOR
Maytag MBF1956KEQ REF - BOTTOM MOUNTS
Maytag MBF1956KEQ11 REFRIGERATOR
Maytag MBF1956KEQ2 REFRIGERATOR
Maytag MBF1956KEQ3 REFRIGERATOR
Maytag MBF1956KEQ4 REFRIGERATOR
Maytag MBF1956KEW REF - BOTTOM MOUNTS
Maytag MBF1956KEW11 REFRIGERATOR
Maytag MBF1956KEW2 REFRIGERATOR
Maytag MBF1956KEW3 REFRIGERATOR
Maytag MBF1956KEW4 REFRIGERATOR
Maytag MBF1958WEB0 REFRIGERATOR
Maytag MBF1958WEB1 REFRIGERATOR
Maytag MBF1958WES0 REFRIGERATOR
Maytag MBF1958WES1 REFRIGERATOR
Maytag MBF1958WES2 REFRIGERATOR
Maytag MBF1958WES3 REFRIGERATOR
Maytag MBF1958WEW0 REFRIGERATOR
Maytag MBF1958WEW1 REFRIGERATOR
Maytag MBF1958XEB0 REFRIGERATOR
Maytag MBF1958XEQ0 REFRIGERATOR
Maytag MBF1958XES0 REFRIGERATOR
Maytag MBF1958XEW0 REFRIGERATOR
Maytag MBF2254HEB REF - BOTTOM MOUNTS
Maytag MBF2254HEB14 REFRIGERATOR
Maytag MBF2254HEB4 REFRIGERATOR
Maytag MBF2254HEQ REF - BOTTOM MOUNTS
Maytag MBF2254HEQ14 REFRIGERATOR
Maytag MBF2254HEQ4 REFRIGERATOR
Maytag MBF2254HES REF - BOTTOM MOUNTS
Maytag MBF2254HEW REF - BOTTOM MOUNTS
  #2 (permalink)
Old 11-20-2011, 06:40 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
I can only suggest you operate it with the front panel off and see if you can determine the source of the problem. It sounds like something is busted in the support structure, and hopefully you can see the problem when it is running.
__________________
  #3 (permalink)
Old 11-27-2011, 10:50 AM
Junior Member
Default
Have run machine with the front panel removed. Nothing appears to be broken.
Upon start of spin cycle the tub/transmission assy seemed to be "stuck" in their normal resting position. Then all of a sudden the same assembly started "swinging" around inside the cabinet until such time the outer tub hit the cabinet. I stopped the machine, redistributed the load and upon restart the tub spooled up and everything was fine. The tub assy was moving inside the cabinet but not to the extent as before.
The manual states, "The washer is designed to reduce spin speed if an unbalanced load is detected". I have not noticed any change is spin speed. the clothes come out nearly dry.
Anyone know how an "unbalance load" is detected and what drives the change in speed?
  #4 (permalink)
Old 12-05-2011, 10:14 AM
Junior Member
Default
Read more: Maytag Atlantis washer out of balance
http://forum.appliancepartspros.com
  #5 (permalink)
Old 12-05-2011, 03:57 PM
Senior Expert
APP Volunteer
Default
I am out of town right now and don't have access to the manual on this machine but it sounds like you got it going ok.
Keep running it with the cabinet off so you can monitor it, but if it is doing what you describe there is either something structurally wrong or you just are having hugely unbalanced loads that should not continue.
__________________
  #6 (permalink)
Old 12-06-2011, 11:04 AM
Junior Member
Default
Any ideas on what is causing the tub assy to "stick" in the resting position? It seems to me this may be contributing to the issue. The dynamic out of balance condition seems to cause the tub assy to break free from the stuck position, then the banging starts.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag Atlantis Clothes Washer MAV-31 mcs800 Washer Repair 3 09-10-2015 07:06 AM
Maytag Atlantis Washer Leaks mpsfinancial Washer Repair 2 09-24-2012 08:47 PM
Maytag Atlantis Washer problems cull53 Washer Repair 1 04-01-2011 04:46 PM
Maytag Atlantis Washer fetz Washer Repair 1 12-15-2009 07:36 PM
Maytag Atlantis Washer rmom3003 Washer Repair 3 07-30-2009 07:09 PM
