If I have power to the motor control board but I have no output to the motor or motor does not run would the appropriate part be Ap4027228 or is this washer worth fixing it is a 2003?
This is a pretty good machine, Maytag got this Neptune version about right. I wold try and fix it. You can order the part from APP and if it does not fix the problem you can return it, see the returns policy for details and conditions, of which there are few.
Good luck, let us know how it turns out.
