i moved over the weekend and my washer was working fine,i started a load of clothes yesterday and my washer just kept running water but wouldnt fill up,i went outside and all the water was draining out side..i have opened the washer and nothing seems to be loose and no hoses are out of place..hope someone can help me.:confused:
Your drain hose needs to be higher than the top of the tub, or it will siphon down the drain!!
Originally Posted by: richappy Your drain hose needs to be higher than the top of the tub, or it will siphon down the drain!! thank you i will try this.
