Discuss
timer advancing but not changing to rinse
 in
Washer Repair
Started delicate cycle and washer filled with water to correct level and agitated and continued to agitate until I stopped
Appliance Repair Forum > Appliance Repair Help > Washer Repair » timer advancing but not changing to rinse
  #1 (permalink)
Old 12-19-2007, 01:52 AM
bdantico bdantico is offline
Junior Member
bdantico is on a distinguished road
Default timer advancing but not changing to rinse
Model Number: sav571eeww   Brand: Maytag   Age: 1 - 5 years
Started delicate cycle and washer filled with water to correct level and agitated and continued to agitate until I stopped it manually. Timer never advanced on machine. Selected regular cycle and agitated and timer advanced through settings on panel but did not empty, spin, or rinse at each arrowed spot. When I move timer manually to rinse and spin the machine will rinse and spin as normal. Also smelled a slight hot electric smell as washer was emptying and spinning after manually moving the timer to rinse and spin. Less than 3 years old.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-19-2007, 06:29 AM
kawfeeman kawfeeman is offline
Senior Expert
APP Volunteer
kawfeeman is on a distinguished road
Default
sounds like a timer contact problem..
__________________
regards
jim
  #3 (permalink)
Old 12-19-2007, 10:48 AM
Junior Member
Default further question
Quote:
Does that mean I need to replace timer or can I clean it and how? If replace can you direct me to part number and diagram on how to replace. Thank you for your help. Brenda
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Need help changing Clock control baize Oven Repair (including Ranges and Cooktops) 3 12-14-2007 05:11 PM
Changing oven elements hup1 Oven Repair (including Ranges and Cooktops) 0 11-12-2007 06:51 PM
Instructions for changing coils Leesa Dryer Repair 2 10-25-2007 08:16 AM
changing thermostat ratboy915 Oven Repair (including Ranges and Cooktops) 3 07-27-2007 09:47 AM
Changing Pump pdiddy Washer Repair 1 07-20-2007 07:05 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
