MY WASHER WILL FILL UP AND NOT AGITATE, WONDER IF ITS THE DOOR SWITCH OR WASHER MOTOR.?? WAS WORKING FINE WE MOVED IT TO FIX FLOOR AND IT QUIT WORKING :confused:
The motors on these machine are very strong and that is probably not the problem.
Check the lid switch, and by-pass it and see if that fixes things. Also, please don't post in all caps, it comes across as you are yelling at us. I get enough yelling at when I am at home.
