| » drive pulley |
Model Number: PAV2200AWW Brand: Maytag Age: 5 - 10 years
Hey All,
Concerning above mentioned washer. I was doing a bit of troubleshooting and removed the drive pulley. I started to replace the drive pulley but, for what ever reason, I don't have enough of the shaft sticking out to put on the retaining washer and clip. Any suggestions are most welcomed. Ads By Google Related Models |
I would go to the web site, www.applianceaid.com for correct washer replacement info. Important you get the washers in the right order.
I have read you can stick a throw pillow on top of the agitator and force the lid down with a heavy object, this will force the spindle down to allow washer replacement. Post reults.
__________________
Sorry, but I have tried all that I have been advised and I am not able resolve this issue. I looked at the diagram to make sure all the washers are correctly aligned and cam properly set. It is if the shaft became shorter suddenly. Is there a way to release the shaft?
| Display Modes | |
| replacing drive coupleing on Whirlpool direct drive washer | bbuck222 | Washer Repair | 2 | 08-06-2009 07:34 AM |
| Bad Pulley? | Fong | Washer Repair | 1 | 07-01-2009 02:53 PM |
| cannot get pulley off | wvmona1 | Washer Repair | 1 | 09-23-2008 12:16 PM |
| drive pulley falls off | daddd | Washer Repair | 2 | 02-03-2008 01:45 PM |
| Whirlpool Direct Drive - reasons for drive coupling failing | FriarTuck | Washer Repair | 1 | 11-12-2007 01:34 PM |
