bought this roper washer yeseday, looked good,but when i ran test cycle, it shake like the devil.i balanced it, when ran a small load of clothes ,still the same,what is wrong,and how to check.dis abled vet cant afford new one,help royboytrip
Remove the outer panel and check for missing springs. Also, check that the tub is sitting evenly on the triangular skate board and that the brown plastic slides on the frame are not worn down or missing, should be three of them.
