Discuss
Duet start button not working
 in
Washer Repair
I am having a problem with my Duet washing machine. All of the buttons on the user control panel work
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Duet start button not working
  #1 (permalink)
Old 11-17-2011, 10:54 AM
Junior Member
MikeW77FSJ is on a distinguished road
Default Duet start button not working
Model Number: GHW9100LW1   Brand: Whirlpool   Age: 5 - 10 years
I am having a problem with my Duet washing machine. All of the buttons on the user control panel work except the start button. Sometimes it will work right away without any problem, sometimes you have to hold it in for 2-3 minutes to get it to start, and other times you have to press and release it several times to get it to start. Opening and shutting the door does not help at all. Changing the load selection does not help either. Here's what I have already done.
1. I took apart the user interface panel to ensure there is good contact between the green start button and the red button behind it. In fact, I pressed the red button by itself and had the same problem, only starts when it wants to.
2. I ran a diagnostic test cycle and received no error codes.
What else should I be checking?
Ads By Google
Related Models
Whirlpool GHW9100LW1
Whirlpool GHW9100LW2 Automatic Washer
Whirlpool GHW9150PW0 Automatic Washer
Whirlpool GHW9150PW1 Automatic Washer
Whirlpool GHW9150PW2 Automatic Washer
Whirlpool GHW9150PW3 Automatic Washer
Whirlpool GHW9150PW4 Automatic Washer
Whirlpool GHW9160PW0 Automatic Washer
Whirlpool GHW9160PW1 Automatic Washer
Whirlpool GHW9160PW2 Automatic Washer
Whirlpool GHW9160PW3 Automatic Washer
Whirlpool GHW9160PW4 Automatic Washer
Whirlpool GHW9200LQ0
Whirlpool GHW9200LW0
Whirlpool GHW9250ML0 Automatic Washer
Whirlpool GHW9250ML1 Automatic Washer
Whirlpool GHW9250ML2 Automatic Washer
Whirlpool GHW9250MQ0 Automatic Washer
Whirlpool GHW9250MQ1 Automatic Washer
Whirlpool GHW9250MQ2 Automatic Washer
Whirlpool GHW9250MT0 Automatic Washer
Whirlpool GHW9250MT1 Automatic Washer
Whirlpool GHW9250MT2 Automatic Washer
Whirlpool GHW9250MW0 Automatic Washer
Whirlpool GHW9250MW1 Automatic Washer
Whirlpool GHW9250MW2 Automatic Washer
Whirlpool GHW9300PW0 Automatic Washer
Whirlpool GHW9300PW1 Automatic Washer
Whirlpool GHW9300PW2 Automatic Washer
Whirlpool GHW9300PW3 Automatic Washer
Whirlpool GHW9300PW4 Automatic Washer
Whirlpool GHW9400PL0 Automatic Washer
Whirlpool GHW9400PL1 Automatic Washer
Whirlpool GHW9400PL2 Automatic Washer
Whirlpool GHW9400PL3 Automatic Washer
Whirlpool GHW9400PL4 Automatic Washer
Whirlpool GHW9400PT0 Automatic Washer
Whirlpool GHW9400PT1 Automatic Washer
Whirlpool GHW9400PT2 Automatic Washer
Whirlpool GHW9400PT3 Automatic Washer
Whirlpool GHW9400PT4 Automatic Washer
Whirlpool GHW9400PW0 Automatic Washer
Whirlpool GHW9400PW1 Automatic Washer
Whirlpool GHW9400PW2 Automatic Washer
Whirlpool GHW9400PW3 Automatic Washer
Whirlpool GHW9400PW4 Automatic Washer
Whirlpool GHW9400SU0 Automatic Washer
Whirlpool GHW9460PL0 Automatic Washer
Whirlpool GHW9460PL1 Automatic Washer
Whirlpool GHW9460PL2 Automatic Washer
Whirlpool GHW9460PL3 Automatic Washer
Whirlpool GHW9460PL4 Automatic Washer
Whirlpool GHW9460PW0 Automatic Washer
Whirlpool GHW9460PW1 Automatic Washer
Whirlpool GHW9460PW2 Automatic Washer
Whirlpool GHW9460PW3 Automatic Washer
Whirlpool GHW9460PW4 Automatic Washer
Whirlpool GHWT160JXX0
Whirlpool GI1500PHB0
Whirlpool GI1500PHB3
Whirlpool GI1500PHB4 Ice Cube Maker
Whirlpool GI1500PHB5 Ice Cube Maker
Whirlpool GI1500PHB6 Ice Cube Maker
Whirlpool GI1500PHB7 Ice Cube Maker
Whirlpool GI1500PHB8 Ice Cube Maker
Whirlpool GI1500PHW0
Whirlpool GI1500PHW3
Whirlpool GI1500PHW4 Ice Cube Maker
Whirlpool GI1500PHW5 Ice Cube Maker
Whirlpool GI1500PHW6 Ice Cube Maker
Whirlpool GI1500PHW7 Ice Cube Maker
Whirlpool GI1500PHW8 Ice Cube Maker
Whirlpool GI1500XHB0
Whirlpool GI1500XHB1
Whirlpool GI1500XHB2
Whirlpool GI1500XHB3
Whirlpool GI1500XHB4 Ice Cube Maker
Whirlpool GI1500XHB5 Ice Cube Maker
Whirlpool GI1500XHB6 Ice Cube Maker
Whirlpool GI1500XHB7 Ice Cube Maker
Whirlpool GI1500XHB8 Ice Cube Maker
Whirlpool GI1500XHB9 Ice Cube Maker
Whirlpool GI1500XHN0
Whirlpool GI1500XHN1
Whirlpool GI1500XHN2
Whirlpool GI1500XHN3
Whirlpool GI1500XHN4 Ice Cube Maker
Whirlpool GI1500XHS0
Whirlpool GI1500XHS1
Whirlpool GI1500XHS2
Whirlpool GI1500XHS3
Whirlpool GI1500XHS4 Ice Cube Maker
Whirlpool GI1500XHS5 Ice Cube Maker
Whirlpool GI1500XHS6 Ice Cube Maker
Whirlpool GI1500XHS7 Ice Cube Maker
Whirlpool GI1500XHS8 Ice Cube Maker
Whirlpool GI1500XHS9 Ice Cube Maker
Whirlpool GI1500XHT1
Whirlpool GI1500XHT2
Whirlpool GI1500XHT3
Whirlpool GI1500XHT4 Ice Cube Maker
Whirlpool GI1500XHT5 Ice Cube Maker
Whirlpool GI1500XHT6 Ice Cube Maker
Whirlpool GI1500XHT7 Ice Cube Maker
Whirlpool GI1500XHT8 Ice Cube Maker
Whirlpool GI1500XHT9 Ice Cube Maker
Whirlpool GI1500XHW0
Whirlpool GI1500XHW1
Whirlpool GI1500XHW2
Whirlpool GI1500XHW3
Whirlpool GI1500XHW4 Ice Cube Maker
Whirlpool GI1500XHW5 Ice Cube Maker
Whirlpool GI1500XHW6 Ice Cube Maker
Whirlpool GI1500XHW7 Ice Cube Maker
Whirlpool GI1500XHW8 Ice Cube Maker
Whirlpool GI1500XHW9 Ice Cube Maker
Whirlpool GI15NDXTB0 Ice Cube Maker
Whirlpool GI15NDXTB1 Ice Cube Maker
Whirlpool GI15NDXTQ0 Ice Cube Maker
Whirlpool GI15NDXTQ1 Ice Cube Maker
  #2 (permalink)
Old 11-19-2011, 06:35 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Strange as it may sound you need to check the door lock assembly and associated wiring. The door lock regularly acts up on these models and it can cause what you are experiencing.
__________________
  #3 (permalink)
Old 11-20-2011, 11:07 AM
Junior Member
Default
I think it is the door lock assembly as well. I used my multi meter to test several components and discovered it was defective. I have had an intermittent problem with it draining as well. Pressure switch was defective as well. Ordered both parts yesterday. Hopefully it will fix my problems.
  #4 (permalink)
Old 11-20-2011, 01:21 PM
Senior Expert
APP Volunteer
Default
Sounds good, let us know how it turns out.
__________________
  #5 (permalink)
Old 11-27-2011, 09:39 AM
Junior Member
Default
OK replacing the door switch had no effect on my problem.
When testing the door lock/unlock solenoids I should be getting 60 ohms for both of them according to my troubleshooting guide. The lock solenoid reads 60 ohms as it should. However the lock solenoid does not. It read 135 ohms for my old door switch, and is reading 118 ohms with my new door switch. Why are the ohms too high, and is this my problem with the start button not working consistently. I checked the wiring harness that connects the door lock switches and solenoids and they were good.
Looking for help!
  #6 (permalink)
Old 11-27-2011, 09:53 AM
Senior Expert
APP Volunteer
Default
Welcome to the wonderful world of Duets. When they work they are great, when they do not they are a diagnostic nightmare.
If your new doorlock did not fix it then the next thing to try is the main control unit. Yes, I know, this sounds like just replacing parts and not figuring out what is wrong. That's what you end up doing with the Duets.
If you bought the parts from this site and they did not fix the problem you can return them, so I can only advise you to keep trying. Sorry, that's what Whirlpool made and that's what a Whirlpool service tech would do if he or she came to your house.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
KUDM01TJBS0 Start Button not working ninaatt Dishwasher Repair 0 05-20-2011 12:15 PM
Dryer start button not working mohr8271 Dryer Repair 1 04-04-2011 03:41 AM
Whirlpool duet wont start when start button is pushed happymom Washer Repair 1 02-02-2011 07:28 AM
Start Button Wont Work On Duet Washer mmcghee Washer Repair 1 08-29-2009 04:39 AM
start /cancle button not working smnas Dishwasher Repair 3 11-05-2007 11:28 AM
