Discuss
washer won't spin or agitate
 in
Washer Repair
The drive belt is not broken, it just slips and burns because the brake prevents the transmission from turning. A
Appliance Repair Forum > Appliance Repair Help > Washer Repair » washer won't spin or agitate
  #1 (permalink)
Old 11-17-2011, 06:38 AM
Junior Member
ctaylor4305 is on a distinguished road
Default washer won't spin or agitate
Model Number: LSE7806ACM stacked   Brand: Maytag   Age: 5 - 10 years
The drive belt is not broken, it just slips and burns because the brake prevents the transmission from turning. A repairman said the tranmission needed to be replaced at a cost of $500.00 plus, he made this diagnoses with no testing and no mention what so ever about the brake. I removed the enclosure, laid the unit on it's side and removed the trans. cover. I expected to see some damage and some reason for the problem, instead it was in perfect condition. when I rotated the shaft in reverse everything worked perfectly when I did the same in foreward the brake would engage and stop the rotation. I can remove the small clip from under the drive pulley and disable the brake and everything rotates in either direction fine. The brake is a sealed unit and I have no idea how to determine if it's bad or not, is their a way to test it? I don't think the trans. is the problem. Please help, Thank You
Ads By Google
Related Models
Maytag LSE7806ACQ Stacked Laundry - Ele
Maytag LSE7806ADE Stacked Laundry - Ele
Maytag LSE7806ADM Stacked Laundry - Ele
Maytag LSE7806ADQ Stacked Laundry - Ele
Maytag LSE7806AEE Stacked Laundry - Ele
Maytag LSE7806BCE Stacked Laundry - Ele
International LSE7806GGE Stacked Laundry - Ele
Whirlpool LSE9355BQ0
Whirlpool LSE9355BZ0
Maytag LSE9900 Stacked Laundry - Ele
Maytag LSE9900ACE Stacked Laundry - Ele
Maytag LSE9900ACL Stacked Laundry - Ele
Maytag LSE9900ACW Stacked Laundry - Ele
Maytag LSE9900ADE Stacked Laundry - Ele
Maytag LSE9900ADL Stacked Laundry - Ele
Maytag LSE9900ADW Stacked Laundry - Ele
Maytag LSE9900AEE Stacked Laundry - Ele
Maytag LSE9900AEL Stacked Laundry - Ele
Maytag LSE9900AEW Stacked Laundry - Ele
Maytag LSE9900AFE Stacked Laundry - Ele
Maytag LSE9900AFL Stacked Laundry - Ele
Maytag LSE9900AFW Stacked Laundry - Ele
Maytag LSE9904ACE Stacked Laundry - Ele
Maytag LSE9904ACL Stacked Laundry - Ele
Maytag LSE9904ACM Stacked Laundry - Ele
Maytag LSE9904ADE Stacked Laundry - Ele
Maytag LSE9904ADL Stacked Laundry - Ele
Maytag LSG1000 Stacked Laundry - Gas
Maytag LSG1000T Stacked Laundry - Gas
Jenn-Air LSG2700W Stacked Laundry - Gas
Jenn-Air LSG2704W Stacked Laundry - Gas
Maytag LSG7800 Stacked Laundry - Gas
Maytag LSG7800AAE Stacked Laundry - Gas
Maytag LSG7800AAL Stacked Laundry - Gas
Maytag LSG7800AAW Stacked Laundry - Gas
Maytag LSG7800ABE Stacked Laundry - Gas
Maytag LSG7800ABL Stacked Laundry - Gas
Maytag LSG7800ABW Stacked Laundry - Gas
Maytag LSG7804AAE Stacked Laundry - Gas
Maytag LSG7804AAL Stacked Laundry - Gas
Maytag LSG7804AAM Stacked Laundry - Gas
Maytag LSG7804ABE Stacked Laundry - Gas
Maytag LSG7804ABL Stacked Laundry - Gas
Maytag LSG7804ABM Stacked Laundry - Gas
Maytag LSG7806AAE Stacked Laundry - Gas
Maytag LSG7806AAM Stacked Laundry - Gas
Maytag LSG7806AAQ Stacked Laundry - Gas
Maytag LSG7806ABE Stacked Laundry - Gas
Maytag LSG7806ABM Stacked Laundry - Gas
Maytag LSG7806ABQ Stacked Laundry - Gas
Maytag LSG9900 Stacked Laundry - Gas
Maytag LSG9900AAE Stacked Laundry - Gas
Maytag LSG9900AAL Stacked Laundry - Gas
Maytag LSG9900AAW Stacked Laundry - Gas
Maytag LSG9900ABE Stacked Laundry - Gas
Maytag LSG9900ABL Stacked Laundry - Gas
Maytag LSG9900ABW Stacked Laundry - Gas
Maytag LSG9904AAE Stacked Laundry - Gas
Maytag LSG9904AAL Stacked Laundry - Gas
Maytag LSG9904AAM Stacked Laundry - Gas
Whirlpool LSH9264HQ0
Whirlpool LSL9244EQ0
Whirlpool LSL9244EZ0
Whirlpool LSL9345EQ0
Whirlpool LSL9345EQ1
Whirlpool LSL9345EZ0
Whirlpool LSL9345EZ1
Whirlpool LSL9355DQ0
Whirlpool LSL9355EQ0
Whirlpool LSL9355EQ1
Whirlpool LSN1000HQ0
Whirlpool LSN1000HZ0
Whirlpool LSN1000JQ0
Whirlpool LSN1000JQ1
Whirlpool LSN1000JT0
Whirlpool LSN1000JT1
Whirlpool LSN1000KQ0
Whirlpool LSN1000KT0
Whirlpool LSN1000LG0
Whirlpool LSN1000LG1 Automatic Washer
Whirlpool LSN1000LG2 Automatic Washer
Whirlpool LSN1000LG3 Automatic Washer
Whirlpool LSN1000LW0
Whirlpool LSN1000LW1 Automatic Washer
Whirlpool LSN1000LW2 Automatic Washer
Whirlpool LSN1000LW3 Automatic Washer
Whirlpool LSN1000PQ0 Automatic Washer
Whirlpool LSN1000PQ1 Automatic Washer
Whirlpool LSN1000PQ2 Automatic Washer
Whirlpool LSN1000PQ3 Automatic Washer
Whirlpool LSN2000JQ0
Whirlpool LSN2000JQ1
Whirlpool LSN2000JQ2
Whirlpool LSN2000JT0
Whirlpool LSN2000JT1
Whirlpool LSN2000JT2
Whirlpool LSN2000LG0
Whirlpool LSN2000LG1 Automatic Washer
Whirlpool LSN2000LW0
Whirlpool LSN2000LW1 Automatic Washer
Whirlpool LSN2000PG0 Automatic Washer
Whirlpool LSN2000PG1 Automatic Washer
Whirlpool LSN2000PG2 Automatic Washer
Whirlpool LSN2000PG3 Automatic Washer
Whirlpool LSN2000PG4 Automatic Washer
Whirlpool LSN2000PW0 Automatic Washer
Whirlpool LSN2000PW1 Automatic Washer
Whirlpool LSN2000PW2 Automatic Washer
Whirlpool LSN2000PW3 Automatic Washer
Whirlpool LSN2000PW4 Automatic Washer
Whirlpool LSN3000PG0 Automatic Washer
Whirlpool LSN3000PG1 Automatic Washer
Whirlpool LSN3000PG2 Automatic Washer
Whirlpool LSN3000PG3 Automatic Washer
Whirlpool LSN3000PG4 Automatic Washer
Whirlpool LSN3000PW0 Automatic Washer
Whirlpool LSN3000PW1 Automatic Washer
Whirlpool LSN3000PW2 Automatic Washer
Whirlpool LSN3000PW3 Automatic Washer
Whirlpool LSN3000PW4 Automatic Washer
  #2 (permalink)
Old 11-18-2011, 06:03 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
If it will agitate find, but will not spin and the motor is turning then it is either the transmission or the brakes that are likely the problem.
It does sound more like the brake is the issue, but I cannot link you to a service manual as Maytag will not let us do this anymore. You will need instructions and a special brake tool to get into this, so I can only suggest you talk to Maytag and see what info they will give you as an owner.
Don't attempt to get into the brakes without that info, it can be dangerous.
__________________
  #3 (permalink)
Old 11-18-2011, 08:28 PM
Junior Member
Default
Thank you for your reply, I actually don't know about the agitator but the rest is accurate, I have already ordered a new brake-clutch assy. I am a mechanic but know little about washers, I can only try to figure out how things work and how they are assembled. I don't have the special wrench and from what I gather on this site It's not available, I did manage to remove the old unit using a chain wrench without too much trouble. I think I will be able to reassemble it as well but I am concerned about possible adjustments. I will try to find some text on the subject.
  #4 (permalink)
Old 11-19-2011, 05:10 AM
Senior Expert
APP Volunteer
Default
Ok, if you have not seen it already here is the exploded viewe of the brake assembly
Clutch & brake replacement parts for MAYTAG LSE7806ACM STACKED LAUNDRY- ELE | AppliancePartsPros.com
Search the Internet for the repair manual; you may find a free download or you may have to pay a nominal fee. Check the auction sites, they frequently have the manuals for these Maytags.
Good luck, and be very careful working with that brake assembly and the brake spring.
__________________
  #5 (permalink)
Old 11-19-2011, 07:26 AM
Junior Member
Default
Will do, Thanks again !
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Washer Won't Spin,Agitate,or Spin (Will Fill) cowboys#1 Washer Repair 8 01-13-2011 10:13 AM
Washer will agitate but not spin/spin slowly sainthooligan Washer Repair 11 07-24-2010 10:34 AM
washer won't agitate or spin busdvr118 Washer Repair 0 06-26-2010 12:28 PM
washer doesn't agitate or spin czy6ltlft Washer Repair 1 01-24-2010 01:38 PM
Washer won't agitate or spin Russel Washer Repair 3 08-03-2009 07:10 AM
