My washer won't spin on the cotton cycle but the soak and delicate cycles work fine. Is this maybe a bad timer?
Since it operates in other cycles, this would suggest that there is no mechanical problem present and that the problem is in the timer. Fortunately it is an inexpensive one, so I would recommend trying it as a fix, but unfortunately from here cannot guarantee it will do the job. Here is your part Replacement parts for ADMIRAL AAV8000AWW | AppliancePartsPros.comGood luck and let us know how it turns out.
