Discuss
roper washer wont work on spin cycle
 in
Washer Repair
washer will fill with water and agitate ,it will drain water ..will not run on spin cycle any ideas what
Appliance Repair Forum > Appliance Repair Help > Washer Repair » roper washer wont work on spin cycle
  #1 (permalink)
Old 05-30-2009, 08:06 AM
Junior Member
bugdude007 is on a distinguished road
Default roper washer wont work on spin cycle
Model Number: ral6245bw1   Brand: Roper   Age: More than 10 years
washer will fill with water and agitate ,it will drain water ..will not run on spin cycle any ideas what i should check? sincerely carl.
Ads By Google
Related Models
Whirlpool RAL6245BW1
Whirlpool RAM4131AL0
Whirlpool RAM4131AW0
Whirlpool RAM4132BW0
Whirlpool RAM4143AL0
Whirlpool RAM4143AL2
Whirlpool RAM4143AW0
Whirlpool RAM4143AW2
Whirlpool RAM5243AL0
Whirlpool RAM5243AL2
Whirlpool RAM5243AW0
Whirlpool RAM5243AW2
Whirlpool RAP5244AL0
Whirlpool RAP5244AW0
Whirlpool RAP7244DW0
Whirlpool RAR81K0
Whirlpool RAS1121EW0
Whirlpool RAS5133EQ0
Whirlpool RAS6233JQ0
Whirlpool RAS6233KQ0
Whirlpool RAS6233KQ1 Automatic Washer
Whirlpool RAS6233KQ2 Automatic Washer
Whirlpool RAS6233PQ0 Automatic Washer
Whirlpool RAS6233PQ1 Automatic Washer
Whirlpool RAS6233PQ3 Automatic Washer
Whirlpool RAS6233RQ0 Automatic Washer
Whirlpool RAS7133KQ0
Whirlpool RAS7133KQ1 Automatic Washer
Whirlpool RAS7133PQ0 Automatic Washer
Whirlpool RAS7133PQ1 Automatic Washer
Whirlpool RAS7133RQ0 Automatic Washer
Whirlpool RAS7133RQ1 Automatic Washer
Whirlpool RAS7133RQ3 Automatic Washer
Whirlpool RAS7133RQ4 Automatic Washer
Whirlpool RAS7233JQ0
Whirlpool RAS7233KQ0
Whirlpool RAS8244KQ0
Whirlpool RAS8244KQ1 Automatic Washer
Whirlpool RAS8244KQ2 Automatic Washer
Whirlpool RAS8244LQ0 Automatic Washer
Whirlpool RAS8244LQ1 Automatic Washer
Whirlpool RAS8245EN0
Whirlpool RAS8245EN1
Whirlpool RAS8245EQ0
Whirlpool RAS8245EQ1
Whirlpool RAS8245EW0
Whirlpool RAS8245EW1
Whirlpool RAS8333PQ0 Automatic Washer
Whirlpool RAS8333PQ1 Automatic Washer
Whirlpool RAS8333RQ0 Automatic Washer
Whirlpool RAS8333RQ1 Automatic Washer
Whirlpool RAS8333RQ3 Automatic Washer
Whirlpool RAS8333RQ4 Automatic Washer
Whirlpool RAS8445JQ0
Whirlpool RAS8445KQ0
Maytag RAX1000AXW Misc / Accessory
Maytag RAX1000CXB Misc / Accessory
Maytag RAX2000AXW Misc / Accessory
Maytag RAX2000CXB Misc / Accessory
Maytag RAX3000DXX Misc / Accessory
Maytag RAX33 Misc / Accessory
Maytag RAX3300CXX Misc / Accessory
Maytag RAX34 Misc / Accessory
Maytag RAX36 Misc / Accessory
Maytag RAX3600CXX Misc / Accessory
Whirlpool RAX4232JQ0
Whirlpool RAX4232KQ0
Whirlpool RAX4232KQ1 Automatic Washer
Whirlpool RAX4232PQ0 Automatic Washer
Whirlpool RAX4232PQ1 Automatic Washer
Whirlpool RAX4232RQ0 Automatic Washer
Whirlpool RAX4232RQ1 Automatic Washer
Whirlpool RAX4232RQ3 Automatic Washer
Whirlpool RAX4232RQ4 Automatic Washer
Whirlpool RAX4233PQ0 Automatic Washer
Maytag RAX5000AXB Misc / Accessory
Maytag RAX5000CXB Misc / Accessory
Maytag RAX5100AXB Misc / Accessory
Whirlpool RAX5133AG0
Whirlpool RAX5133AL0
Whirlpool RAX5133AL1
Whirlpool RAX5133AW0
Whirlpool RAX5133AW1
Maytag RAX5200AXB Misc / Accessory
Maytag RAX5200CXB Misc / Accessory
Maytag RAX5300AXB Misc / Accessory
Maytag RAX5400AXB Misc / Accessory
Maytag RAX5500AXB Misc / Accessory
Maytag RAX5500CXB Misc / Accessory
Maytag RAX5600AXB Misc / Accessory
Maytag RAX5700AXB Misc / Accessory
Maytag RAX5700CXB Misc / Accessory
Whirlpool RAX6144EN0
Whirlpool RAX6144EN1
Whirlpool RAX6144EQ0
Whirlpool RAX6144EQ1
Whirlpool RAX6144EW0
Whirlpool RAX6144EW1
Whirlpool RAX7244EN0
Whirlpool RAX7244EN1
Whirlpool RAX7244EQ0
Whirlpool RAX7244EQ1
Whirlpool RAX7244EW0
Whirlpool RAX7244EW1
Whirlpool RAX7244JQ0
Whirlpool RAX7244KQ0
Whirlpool RAX7244KQ1 Automatic Washer
Whirlpool RAX7244KQ2 Automatic Washer
Whirlpool RAX7244PQ0 Automatic Washer
Whirlpool RAX7244PQ1 Automatic Washer
Whirlpool RAX7245AG0
Whirlpool RAX7245AL0
Whirlpool RAX7245AW0
Whirlpool RAX7245BL0
Whirlpool RAX7245BL1
Whirlpool RAX7245BQ1
Whirlpool RAX7245BW0
Whirlpool RAX7245BW1
Whirlpool RAX7245JQ0
Whirlpool RAX7245KQ0
  #2 (permalink)
Old 05-31-2009, 10:10 AM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi Carl
The first thing you want to do is check the lid switch. You can do this by unplugging the machine and then taking out the two screws that hold the console to the top and flipping back the console.
You will see a plastic connector coming from the console with the other end going into the cabinet. Disconnect this and using an insulated solid electrical wire insert each end into the outer holes on the connector coming from the console. This will by-pass the lid switch.
Plug the machine back in, move the selector to spin and engage it. If the machine spins, replace the lid switch.
Good luck and let us know how it turns out.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
roper washer not spinning on spin cycle walkm0217 Washer Repair 4 12-07-2009 01:30 PM
kenmore washer spin cycle does not work saved Washer Repair 7 11-08-2009 02:22 PM
Roper washer wont spin and wont empty jgirl14572 Washer Repair 2 10-11-2009 06:54 AM
doesn't always spin cycle Roper Washer kalahiki Washer Repair 8 07-12-2009 03:41 PM
Washer spin cycle does not work valerie Washer Repair 5 05-20-2008 03:48 PM
