I bought a new control board from appliance repair pros and I now have more issues and errors than I did before. I heard these have to sometimes be programmed. Serial number is 14262647JA....specifically the code is e3.
Melissa
Troubleshooting and fixing this model is a real nightmare. Check all of your connections between the control unit and the motor and motor control unit.
If all is ok, try replacing the motor control unit.
Thank you for your response. We actually determined that we got the wrong part, we needed a 34001494 but received a 34001495. It made a big difference! We installed the control board which does not need programmed, it's actually very easy to install and the washer is working great!
Well sorry you got the wrong part but really glad you figured it out and got the machine going.
Thanks for updating us, good luck going forward.
