Appliance Repair Forum
Appliance Repair Forum (
-   Washer Repair (
-   -   Maytag Neptune washer control board (
Melstvincent 11-15-2011 03:28 PM
I bought a new control board from appliance repair pros and I now have more issues and errors than I did before. I heard these have to sometimes be programmed. Serial number is 14262647JA....specifically the code is e3.
sidfink43 11-17-2011 06:25 PM
Troubleshooting and fixing this model is a real nightmare. Check all of your connections between the control unit and the motor and motor control unit.
If all is ok, try replacing the motor control unit.
Melstvincent 11-17-2011 06:45 PM
Thank you for your response. We actually determined that we got the wrong part, we needed a 34001494 but received a 34001495. It made a big difference! We installed the control board which does not need programmed, it's actually very easy to install and the washer is working great!
sidfink43 11-18-2011 04:52 AM
Well sorry you got the wrong part but really glad you figured it out and got the machine going.
Thanks for updating us, good luck going forward.
