Discuss
Whirlpool Washer won't complete cycle
 in
Washer Repair
Washing machine will start but will than stop part way through wash cycle. At that point, none of the cycles
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Washer won't complete cycle
  #1 (permalink)
Old 05-28-2009, 09:46 PM
Junior Member
ancient1 is on a distinguished road
Default Whirlpool Washer won't complete cycle
Model Number: LSC8244BNI   Brand: Whirlpool   Age: More than 10 years
Washing machine will start but will than stop part way through wash cycle. At that point, none of the cycles work. However, repeated pushing cycle selector off and pulling back on, coupled with trying various cycle positions eventually results in a restart on whatever cycle happens to be selected. I just replaced the timer unit and was able to do about five loads without incident. However, the problem has returned. Given that the timer is most likely not the problem, I'm thinking that maybe there is a relay or something else electrical that isn't functioning correctly. How to troubleshoot? Any other ideas or suggestions?
Thanks!
Ads By Google
Related Models
Whirlpool LSC8244BQ0
Whirlpool LSC8244BQ1
Whirlpool LSC8244BW0
Whirlpool LSC8244BW1
Whirlpool LSC8244BZ0
Whirlpool LSC8244BZ1
Whirlpool LSC8244DQ0
Whirlpool LSC8244DZ0
Whirlpool LSC8244EQ0
Whirlpool LSC8244EQ1
Whirlpool LSC8244EZ0
Whirlpool LSC8244EZ1
Whirlpool LSC8245AN0
Whirlpool LSC8245AQ0
Whirlpool LSC8245AW0
Whirlpool LSC8245BN0
Whirlpool LSC8245BW0
Whirlpool LSC9000PW0 Automatic Washer
Whirlpool LSC9000PW1 Automatic Washer
Whirlpool LSC9000PW2 Automatic Washer
Whirlpool LSC9245BN0
Whirlpool LSC9245BN1
Whirlpool LSC9245BQ0
Whirlpool LSC9245BQ1
Whirlpool LSC9245BW0
Whirlpool LSC9245BW1
Whirlpool LSC9245BZ0
Whirlpool LSC9245BZ1
Whirlpool LSC9355AG0
Whirlpool LSC9355AN0
Whirlpool LSC9355AW0
Whirlpool LSC9355BN0
Whirlpool LSC9355BN1
Whirlpool LSC9355BQ0
Whirlpool LSC9355BQ1
Whirlpool LSC9355BW0
Whirlpool LSC9355BW1
Whirlpool LSC9355BZ0
Whirlpool LSC9355BZ1
Whirlpool LSC9355DQ0
Whirlpool LSC9355DZ0
Whirlpool LSC9355EQ0
Whirlpool LSC9355EQ1
Whirlpool LSC9355EZ0
Whirlpool LSC9355EZ1
Admiral LSD2615HEB Ref - SXS/I&W
Admiral LSD2615HEW Ref - SXS/I&W
Admiral LSD2615HEZ Ref - SXS/I&W
Maytag LSE1000 Stacked Laundry - Ele
Maytag LSE1000T Stacked Laundry - Ele
Jenn-Air LSE2700W Stacked Laundry - Ele
Jenn-Air LSE2700W-8 Stacked Laundry - Ele
Jenn-Air LSE2700W-C Stacked Laundry - Ele
Jenn-Air LSE2704W Stacked Laundry - Ele
Jenn-Air LSE2704W-8 Stacked Laundry - Ele
Maytag LSE7800 Stacked Laundry - Ele
Maytag LSE7800ACE Stacked Laundry - Ele
Maytag LSE7800ACL Stacked Laundry - Ele
Maytag LSE7800ACW Stacked Laundry - Ele
Maytag LSE7800ADE Stacked Laundry - Ele
Maytag LSE7800ADL Stacked Laundry - Ele
Maytag LSE7800ADW Stacked Laundry - Ele
Maytag LSE7800AEE Stacked Laundry - Ele
Maytag LSE7800AEL Stacked Laundry - Ele
Maytag LSE7800AEW Stacked Laundry - Ele
International LSE7800AGE Stacked Laundry - Ele
International LSE7800AGL Stacked Laundry - Ele
Maytag LSE7804ACE Stacked Laundry - Ele
Maytag LSE7804ACL Stacked Laundry - Ele
Maytag LSE7804ACM Stacked Laundry - Ele
Maytag LSE7804ADE Stacked Laundry - Ele
Maytag LSE7804ADL Stacked Laundry - Ele
Maytag LSE7804ADM Stacked Laundry - Ele
Maytag LSE7804AEE Stacked Laundry - Ele
International LSE7804AGE Stacked Laundry - Ele
International LSE7804AGL Stacked Laundry - Ele
International LSE7804AGM Stacked Laundry - Ele
Maytag LSE7806ACE Stacked Laundry - Ele
Maytag LSE7806ACM Stacked Laundry - Ele
Maytag LSE7806ACQ Stacked Laundry - Ele
Maytag LSE7806ADE Stacked Laundry - Ele
Maytag LSE7806ADM Stacked Laundry - Ele
Maytag LSE7806ADQ Stacked Laundry - Ele
Maytag LSE7806AEE Stacked Laundry - Ele
Maytag LSE7806BCE Stacked Laundry - Ele
International LSE7806GGE Stacked Laundry - Ele
Whirlpool LSE9355BQ0
Whirlpool LSE9355BZ0
Maytag LSE9900 Stacked Laundry - Ele
Maytag LSE9900ACE Stacked Laundry - Ele
Maytag LSE9900ACL Stacked Laundry - Ele
Maytag LSE9900ACW Stacked Laundry - Ele
Maytag LSE9900ADE Stacked Laundry - Ele
Maytag LSE9900ADL Stacked Laundry - Ele
Maytag LSE9900ADW Stacked Laundry - Ele
Maytag LSE9900AEE Stacked Laundry - Ele
Maytag LSE9900AEL Stacked Laundry - Ele
Maytag LSE9900AEW Stacked Laundry - Ele
Maytag LSE9900AFE Stacked Laundry - Ele
Maytag LSE9900AFL Stacked Laundry - Ele
Maytag LSE9900AFW Stacked Laundry - Ele
Maytag LSE9904ACE Stacked Laundry - Ele
Maytag LSE9904ACL Stacked Laundry - Ele
Maytag LSE9904ACM Stacked Laundry - Ele
Maytag LSE9904ADE Stacked Laundry - Ele
Maytag LSE9904ADL Stacked Laundry - Ele
Maytag LSG1000 Stacked Laundry - Gas
Maytag LSG1000T Stacked Laundry - Gas
Jenn-Air LSG2700W Stacked Laundry - Gas
Jenn-Air LSG2704W Stacked Laundry - Gas
Maytag LSG7800 Stacked Laundry - Gas
Maytag LSG7800AAE Stacked Laundry - Gas
Maytag LSG7800AAL Stacked Laundry - Gas
Maytag LSG7800AAW Stacked Laundry - Gas
Maytag LSG7800ABE Stacked Laundry - Gas
Maytag LSG7800ABL Stacked Laundry - Gas
Maytag LSG7800ABW Stacked Laundry - Gas
Maytag LSG7804AAE Stacked Laundry - Gas
Maytag LSG7804AAL Stacked Laundry - Gas
Maytag LSG7804AAM Stacked Laundry - Gas
  #2 (permalink)
Old 05-30-2009, 02:02 PM
Senior Expert
APP Volunteer
sidfink43 has a spectacular aura about
Default
Hi Ancient 1
I think you are correct in that you do have an electrical problem. It is possible there is a break in the wiring between the timer and the motor switch, and you should check each wire for continuity with a meter. Jiggle the wires as you do it.
Unfortunately, finding something like this is very difficult, particularly in your case where your problem is on again/off again.
Another possibility is in your motor switch. (sort of a relay like you were thinking) It is a mediumly expensive part if you want to try it as a fixbut unfortunately I cannot be certain that it will do the job.
Replacement parts for WHIRLPOOL LSC8244BN1 | AppliancePartsPros.com
Good luck and let us know how it works out.
__________________
  #3 (permalink)
Old 05-30-2009, 06:02 PM
Junior Member
Default
Thank you for your response. My wife is thinking 'new washer' so I'll get to checking the wiring right away. I don't know if she'll be patient enough for a new motor switch. Hopefully I'll find something in the wiring.
Thanks again. Very much appreciated.
  #4 (permalink)
Old 05-30-2009, 06:12 PM
Senior Expert
APP Volunteer
Default
Good luck, that "wife wants a new washer" is a horror we have all been through.
If you go that route I recommend the basic, no frills top loading machine. It will cost less, do just as well as a fancy washer and be less likely to need repairs.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool dishwasher cuts out before cycle is complete tobester7 Dishwasher Repair 0 01-23-2010 05:08 PM
Washer will not complete cycle KeithVogt Washer Repair 0 11-23-2009 08:50 AM
GE washer won't complete cycle damselNdistress Washer Repair 13 06-05-2009 06:23 AM
Whirlpool dishwasher taking 12+ hours to complete a cycle - please help! becstar Dishwasher Repair 4 03-04-2009 11:26 AM
Washer will not complete cycle nicole Jones Washer Repair 6 11-17-2008 09:23 AM
