Appliance Repair Forum
Appliance Repair Forum (
-   Washer Repair (
-   -   Motor Sliding. (
zaw 11-14-2011 05:15 PM
Motor Sliding.
It was making a a lots of noise during spin and and wash so I look under the.
Found that belt is Wrong off and about to break!
Motor Pulley have a lot of crap from belt on there. Probably get pulley replace too.
I've replace the Transmission on this thing once. but I don't remember how the motor should sit.
When I removed the belt and check thing out, motor sides back and forth freely. Thought need tension so I tighten the lock nuts but they don't seem to do anything.
I have Belt and Pulley in cart now, I wonder if I need something else to keep that motor is place or that how it work.
Even with loose motor and worn out belt, washer still works.
sidfink43 11-16-2011 06:50 PM
The motor is loose so that it can pivot which acts as a clutch.
