Discuss
partial filling-tired of doing half loads
 in
Washer Repair
Washer works perfectly through all cycles but water won't fill up all the way to the full level in
Appliance Repair Forum > Appliance Repair Help > Washer Repair » partial filling-tired of doing half loads
  #1 (permalink)
Old 12-17-2007, 11:49 AM
bulldozerbob bulldozerbob is offline
Junior Member
bulldozerbob is on a distinguished road
Question partial filling-tired of doing half loads
Model Number: LA450JXW5   Brand: White-Westinghouse   Age: 5 - 10 years
Washer works perfectly through all cycles but water won't fill up all the way to the full level in any cycle. Should I go straight for the water inlet valve or could it be something I'm unfamiliar with? And no, there are no leaks.....Thanks a million....Bob
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-17-2007, 02:32 PM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
did you try to reset your water level switch, if so the water level[pressure] switch could be bad .
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
No Heat 3 Loads After Element Replacement jtagscott Dryer Repair 4 12-11-2007 02:36 PM
maytag half will half wont oneleg$ Refrigerator & Freezer Repair 1 10-12-2007 05:31 AM
Window A/c Working Half Efficiency srbishoplx Heating, Ventilation, and Air Conditioning (HVAC) 1 08-06-2007 07:47 PM
Dryer stops before loads are dry,esp on High setting azhorn Dryer Repair 2 08-02-2007 04:05 PM
spin dry only on light loads gwc36@verizon.net Washer Repair 1 07-27-2007 05:36 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
