| » Washer won't fill with water |
Model Number: GVW9959KQ2 Brand: Whirlpool Age: 5 - 10 years
I hade a problem with the washer macine not draining at first, I took the Drain pump apart and found a cloth stuck in it. Cleaned the Drain pump out. It worked for one load of laundry until it had to spin and after the spin. After the spin the washer signal Ld (long drain). After the first load the tube stopped filling with water. What can be wrong with it now. it seems like the water is not entering the tube. Thanks Ads By Google Related Models |
My guess, and it is only a guess at this point, particularly with these machines, is that the pump has been damaged. Take a look and see if you can determine its condition.
Here is the service manual, which should also help in your diagnosis. http://adcxns1.whirlpool.com/Service...LE/8178010.pdf Good luck, and let us know what you find out.
__________________
| Display Modes | |
| washer will not fill with water | molarkey | Washer Repair | 5 | 01-03-2010 04:50 PM |
| washer water won't fill | andhow | Washer Repair | 0 | 07-18-2008 12:20 PM |
| Washer won't fill with water | gimpy54 | Washer Repair | 6 | 07-03-2008 11:20 AM |
| washer doesn't fill with water | cla | Washer Repair | 2 | 02-06-2008 03:30 PM |
| GE washer will not fill with water | tex | Dishwasher Repair | 1 | 08-30-2007 11:33 AM |
