Discuss
Whirlpool Duet Sport Error Code F30
 in
Washer Repair
Great, thanks for sharing that with us because trouble shooting these models is very difficult. Good luck with your machine.
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Whirlpool Duet Sport Error Code F30
  #11 (permalink)
Old 07-30-2010, 06:19 AM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
__________________
  #12 (permalink)
Old 10-30-2010, 10:21 PM
Junior Member
dhole is on a distinguished road
Default Error code F30 caused by stuck lever
Thanks for all of the useful information here. Thanks to the previous posters, I knew where to look when my washer stopped with the F30 code. Since my wife had just left town for meetings, I knew I was going to get blamed for it. The lever (part AP3868475) had somehow ridden up over the stop pin that should stop the travel of the lever so it can begin to return. With the lever caught on that pin, it couldn't move at all, and the motor was making loud noises like plastic gears being forced to skip. Simply releasing the lever from where it was trapped allowed it to operate correctly. Thanks again for all of the help.
  #13 (permalink)
Old 10-31-2010, 06:47 AM
Senior Expert
APP Volunteer
Default
Dhole
Thanks for your post, glad you got it going.
__________________
  #14 (permalink)
Old 11-01-2010, 06:23 PM
Junior Member
tomhynes is on a distinguished road
Default Still stuck on F30
I have read above and found them helpful.
My washer was stuck on F30 - it wouldn't even start a cycle. I took off top, jiggled things. Now it will start, water flows, but at the 17 minute mark (of a 28 minute cycle) I get the F30.
The motor works, and moves the arms.
The water flows.
I removed the whole container for bleach/detergent, thinking that might interfere, runs, but still stops at 17 minute mark.
Any ideas?
  #15 (permalink)
Old 04-25-2012, 05:09 PM
Junior Member
CrispexX is on a distinguished road
Default
Hello and think you all with your previous posts this site has helped me with a lot of my appliances, but as for my washer i took the top off ran a few cycles and found when the lever (AP3868475) moved from position I to position II the the lever (AP3868475) would bend UPWARDS and not towards position II, so im thinking a new lever is needed as this one seems slightly curved upwards as this has probably been happening for a while but finally got stuck and threw the code. I hope this helps anyone else as everyone else has helped me!!
  #16 (permalink)
Old 06-30-2013, 11:21 AM
Junior Member
garage elf is on a distinguished road
Default error code F30 solved
Good info found on this forum.
I downloaded the service manual and removed the top cover - three torx-20 screws on the back edge and the soap dispenser has a plastic armature that had hard water gunk interferring with this. Cleaned that off with a toohbrush and some vinegar and the mechanism worked perfectly.
Wife is happy again, all is well in the world.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Whirlpool Duet Sport washer F-01 error Penypincher Washer Repair 3 01-24-2015 06:09 PM
whirlpool Duet error code H/F androck Washer Repair 3 08-18-2013 07:14 AM
Whirlpool Duet error code F06 rhamiltonnc Washer Repair 8 02-27-2013 06:18 PM
error codes on whirlpool duet sport Thad Steele Washer Repair 4 05-09-2011 10:01 PM
Duet Sport F01 error Code vposton Washer Repair 2 09-15-2007 08:20 AM
