| » Will not drain or spin... |
Model Number: RAS7133KQ1 Brand: Roper Age: 1 - 5 years
Washer will fill and aggitate but will not drain. Timer works good on all cycles but appears to stop after the wash cycle. Knob rotates and feels ok. Removed pump and it's clear and rotates freely. Checked motor and it rotates freely.
Most likely the problem with your washer is a bad lid switch (#11 on the top & cabinet break down diagram).
Open the control panel, unplug the lid switch connector and check continuity. With the lid closed the lid switch should be closed. Replace if it's open. - The part number for the lid switch is AP3100003 - Here are the break down diagrams for the Roper washer Model RAS7133KQ1 Gene.
__________________
Professional appliance repair in Los Angeles, California. |
| Display Modes | |
| Will not drain or spin. | PJ3 | Washer Repair | 1 | 11-15-2007 06:14 PM |
| Frigidaire won't spin or drain | Buckythecat | Washer Repair | 0 | 11-06-2007 11:30 AM |
| drain/spin problem | lymtics | Washer Repair | 1 | 10-29-2007 04:48 PM |
| washer will not spin or drain | Martha Shelby | Washer Repair | 2 | 10-25-2007 03:43 AM |
| washer will not spin or drain | Martha Shelby | Washer Repair | 1 | 10-24-2007 04:59 AM |
