Discuss
Admiral Washer Spin Cycle Not Working
 in
Washer Repair
We Have A Admiral Washer Model No. Lnc6759a77 Rev. 14 Serial Number 14828715uw. The Problem Started About 3 Weeks Ago,
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Admiral Washer Spin Cycle Not Working
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
LinkBack (1) Thread Tools Search this Thread Display Modes
  1 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 12-16-2007, 02:59 PM
achetwood achetwood is offline
Junior Member
achetwood is on a distinguished road
Red face Admiral Washer Spin Cycle Not Working
Model Number: LNC6759A77 REV 14   Brand: Admiral   Age: More than 10 years
We Have A Admiral Washer Model No. Lnc6759a77 Rev. 14 Serial Number 14828715uw. The Problem Started About 3 Weeks Ago, Everything Works Fine But We Started To Notice That The Tub Would Remain Full Of Water When We Expected To Unload It To The Dryer. We Would Simply Move It To A Spin Cycle And It Would Complete. Eventually Over The Last 3 Weeks Things Progressively Got Worse. We Would Eventually Have To Spin The Dial 1, 2+ Times And It Would Start On A Spin Cycle. Today It's Done...it Will Not Start On Any Spin Cycle No Matter How Many Times We Turn The Dial; I Tried Unplugging And Plugging Back In...nothing. It Fills, Washes, Rinses Fine, But Nothing Will Happen On The Spin Cycle. I Read Another Post That Indicate It Could Be The Timer On That Model. I'm Not Well Versed In These Things So I Don't Know If The Solution Would Be The Same For My Model. Any Help Would Be Appreciated. The Wife Wants A New Washer....i Want The Cheapest Way Out!
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-17-2007, 12:34 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Most likely the problem is a bad timer.
- The part number for the timer is AP246695.
__________________
Professional appliance repair services in Orange County, California.
  #3 (permalink)
Old 12-17-2007, 06:38 PM
Junior Member
Default Didn't Think Of That??
OK, so I went to the local appliance depot store to buy the timer. The guy behind the counter said to try and check the lid switch before I install the timer; apparently on some models when the lid switch malfunctions it will affect the spin cycle. I got home, removed the switch and just connected them directly to test...spin cycle working once again as it should. Instead of a $100 part, I now only need a $40 part. Some of you out there may want to try this out too. I'd also noticed that one end of the switch was tarnishing and corroded; I'm sure that's why it doesn't work as good.
  #4 (permalink)
Old 12-17-2007, 06:44 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
I'm glad you were able to fix it.
Merry Christmas and Happy New year!
__________________
Reply
LinkBacks (?)
LinkBack to this Thread: http://forum.appliancepartspros.com/washer-repair/3480-admiral-washer-spin-cycle-not-working.html
Posted By For Type Date
Blogs - Admiral Washer Spin Cycle Not Working A Admiral This thread Refback 02-04-2008 02:22 PM
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer leaks during spin cycle harryupson Washer Repair 0 11-30-2007 07:18 AM
washer want start the spin cycle without help? elizabeth Washer Repair 0 11-23-2007 06:41 PM
Washer will not spin on spin cycle bellboy Washer Repair 0 11-11-2007 08:16 AM
washer won't drain and move to the spin cycle dwillia1 Washer Repair 0 09-14-2007 08:10 AM
Washer noise on spin cycle...not unbalanced load marykelly7 Washer Repair 3 08-12-2007 08:50 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
