Discuss
GE washer/not draining/pump works/not clogged/not lid switch
 in
Washer Repair
GE top load washer doesn't drain on any of the cycles. Electric pump tests good out of machine. Water drains
Appliance Repair Forum > Appliance Repair Help > Washer Repair » GE washer/not draining/pump works/not clogged/not lid switch
  #1 (permalink)
Old 11-11-2011, 12:33 PM
Junior Member
mikethereal is on a distinguished road
Question GE washer/not draining/pump works/not clogged/not lid switch
Model Number: wvsr1060a1ww   Brand: GE   Age: 1 - 5 years
GE top load washer doesn't drain on any of the cycles. Electric pump tests good out of machine. Water drains when hose is lowered (not clogged). Lid switch is good (it spins). Can it be the the water level switch? Am I wrong in assuming it's not the cycle selector switch? Is there a test point on the switch for pump voltage? I see on a diagram,that the line voltage comes from R8-R9/R22-R23/R2-R1. Are these terminals at the switch?
I'm trying to help my able (not employed) sister, long distance, over the phone. Any help? Thanks.
Related Models
General Electric WVSR1060A1WW Washer
General Electric WVSR1060A2AA Washer
General Electric WVSR1060A2WW Washer
General Electric WVSR1060B0WW Washer
General Electric WVSR1060B3WW Washer
General Electric WVSR1060B4WW Washer
General Electric WVSR1060D0WW Washer
General Electric WVSR1060D2WW Washer
General Electric WVSR1060D5WW Washer
General Electric WVSR1060DAWW Washer
General Electric WVSR1060DBWW Washer
General Electric WVSR1060DCWW Washer
General Electric WVSR1060DDWW Washer
General Electric WVSR1060G0WW Washer
General Electric WVSR1060G2WW Washer
General Electric WVSR1060G3WW WASHER
General Electric WVSR1060G5WW WASHER
General Electric WVSR1060G6WW WASHER
General Electric WVSR1060G7WW WASHER
General Electric WVSR1060G8WW WASHER
General Electric WVSR1060G9WW WASHER
General Electric WVSR1080G8WW WASHER
General Electric WVXR1040T2WW Washer
General Electric WVXR1040T3WW Washer
General Electric WVXR1040T4WW Washer
General Electric WVXR1040T5WW Washer
General Electric WVXR1040T8WW Washer
General Electric WVXR1040TAWW Washer
Jenn-Air WW2460B WALLOVEN- S/C ELE
Jenn-Air WW2460W WALLOVEN- S/C ELE
Jenn-Air WW27110B WALLOVEN- S/C ELE
Jenn-Air WW27110W WALLOVEN- S/C ELE
Jenn-Air WW27210B WALLOVEN- S/C ELE
Jenn-Air WW27210P WALLOVEN- S/C ELE
Jenn-Air WW27210PF WALLOVEN- S/C ELE
Jenn-Air WW27210PG WALLOVEN- S/C ELE
Jenn-Air WW27210PK WALLOVEN- S/C ELE
Jenn-Air WW27210PR WALLOVEN- S/C ELE
Jenn-Air WW27210PU WALLOVEN- S/C ELE
Jenn-Air WW27210W WALLOVEN- S/C ELE
Jenn-Air WW27430B WALLOVEN- S/C ELE
Jenn-Air WW27430BC WALLOVEN- S/C ELE
Jenn-Air WW27430P WALLOVEN- S/C ELE
Jenn-Air WW27430PF WALLOVEN- S/C ELE
Jenn-Air WW27430PG WALLOVEN- S/C ELE
Jenn-Air WW27430PK WALLOVEN- S/C ELE
Jenn-Air WW27430PR WALLOVEN- S/C ELE
Jenn-Air WW27430PU WALLOVEN- S/C ELE
Jenn-Air WW27430W WALLOVEN- S/C ELE
Jenn-Air WW27430WC WALLOVEN- S/C ELE
Jenn-Air WW2750B WALLOVEN- S/C ELE
Jenn-Air WW2750W WALLOVEN- S/C ELE
Jenn-Air WW2780B WALLOVEN- S/C ELE
Jenn-Air WW2780B-C WALLOVEN- S/C ELE
Jenn-Air WW2780W WALLOVEN- S/C ELE
Jenn-Air WW2780W-C WALLOVEN- S/C ELE
Whirlpool WW29000SU0 LAUNDRY WORKSURFACE
Whirlpool WW29000SW0 LAUNDRY WORKSURFACE
Jenn-Air WW30110B WALLOVEN- S/C ELE
Jenn-Air WW30110W WALLOVEN- S/C ELE
Jenn-Air WW30430B WALLOVEN- S/C ELE
Jenn-Air WW30430P WALLOVEN- S/C ELE
Jenn-Air WW30430PC WALLOVEN- S/C ELE
Jenn-Air WW30430PF WALLOVEN- S/C ELE
Jenn-Air WW30430PG WALLOVEN- S/C ELE
Jenn-Air WW30430PK WALLOVEN- S/C ELE
Jenn-Air WW30430PR WALLOVEN- S/C ELE
Jenn-Air WW30430PU WALLOVEN- S/C ELE
Jenn-Air WW30430W WALLOVEN- S/C ELE
Frigidaire WW334AGW0 Wwh(v1) / Washer
Frigidaire WW334AGW1 Wwh(v2) / Washer
Frigidaire WW334AGW2 Wwh(v3) / Washer
 WW600 MWAVE- CNTRTP / STAND ALONE
General Electric WW8318LAL AUTOMATIC WASHER
General Electric WWA3100BAL Washer
General Electric WWA3100GAL Washer
General Electric WWA3100GBL Washer
General Electric WWA3100VCL Washer
General Electric WWA3650MAL Washer
General Electric WWA3650RBL Washer
General Electric WWA3650SALAD Washer
General Electric WWA3650SALHA Washer
General Electric WWA3650SALWH Washer
General Electric WWA3657SALHA Washer
General Electric WWA3657SALWH Washer
General Electric WWA5009VCL Washer
General Electric WWA5304VNL Washer
General Electric WWA5304VPL Washer
General Electric WWA5400SALWH Washer
General Electric WWA5400SBLWH Washer
General Electric WWA5407MAL Washer
General Electric WWA5411BAL Washer
General Electric WWA5411GAL Washer
General Electric WWA5411VEL Washer
General Electric WWA5412BAL Washer
General Electric WWA5412GAL Washer
General Electric WWA5412VEL Washer
General Electric WWA5509VCL Washer
General Electric WWA5600BAL Washer
General Electric WWA5600GAL Washer
General Electric WWA5600GBL Washer
General Electric WWA5600RBL Washer
General Electric WWA5600SALAA Washer
General Electric WWA5600SALHA Washer
General Electric WWA5600SALWW Washer
General Electric WWA5600SBLAA Washer
General Electric WWA5600SBLWW Washer
General Electric WWA5600VCL Washer
General Electric WWA5610BAL Washer
General Electric WWA5636MAL Washer
General Electric WWA5669MAL Washer
General Electric WWA5669MBL Washer
General Electric WWA5710MAL Washer
General Electric WWA5710RBL Washer
General Electric WWA5710SALAA Washer
General Electric WWA5710SALWW Washer
General Electric WWA5710SBLAA Washer
General Electric WWA5710SBLWW Washer
General Electric WWA5800BAL Washer
General Electric WWA5800GAL Washer
  #2 (permalink)
Old 11-11-2011, 12:44 PM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Run it through a cycle, with a small amount of water. When it comes to the drain cyce, check for 120VAC at the pump.
  #3 (permalink)
Old 11-11-2011, 01:09 PM
Junior Member
Default
Quote:
Sorry, thought that I was clearer than that. No voltage at pump during drain cycle. Pump works when plugged into 120v.
  #4 (permalink)
Old 11-11-2011, 01:14 PM
Senior Expert
APP Volunteer
Default
Sounds like a faulty timer.
Part number: AP2045950
  #5 (permalink)
Old 11-11-2011, 01:25 PM
Junior Member
Default
Quote:
Thanks, because of shipping to the middle of no-where and the time involved I was hoping for a test point to make sure. My sister already bought a pump and when I told her how to test the old one, found out it was still good.
  #6 (permalink)
Old 11-11-2011, 06:37 PM
Junior Member
whitebike is on a distinguished road
Default okay, then..
I have a similar problem. Washer fills, agitates, spins, but doesn't drain. It does not drain after the wash cycle, nor during the spin/dry cycle. When I take the drain hose out, and put it lower than the washer, drains just fine....so no hoses are blocked.
Pulled the pump out..it's sitting right here.
Took an old extension cord, stripped the wires...plugged it in....now, when I touch the wires to the two blade connectors on the pump body...that pump oughtta spin, right?
Thanks,
Rob "I don't know nothin' 'bout electricity" Hall
  #7 (permalink)
Old 11-11-2011, 06:52 PM
Senior Expert
APP Volunteer
Default
The most important thing you need to know about electricity is that it will kill you.
Yes, the pump should run when you hook up the test cord. If it doesn't, you need to replace it.
  #8 (permalink)
Old 11-14-2011, 06:53 PM
Junior Member
Default yabbut...
thanks, magician.
Now for the follow up...the website shows a new pump...looks very different from my stone-age pump, which looks like a design from the 1950's..probably was, although the washer's only 10 years old.
Anyway, the part that every website lists for my replacement pump looks like an upgrade, but overall dimensions and bracket appear similar. Output spigot is different, but the drain hose from the tub is plenty long and flexy to hook up.
I'm assuming the pump was updated...so I went ahead and ordered it.
Somebody please tell me I did the right thing....
It's a GE WBXR2060V2WW model washer....and the fact that I can type that from memory should indicate how much time I've put into hunting down a replacement pump....
Oh, yeah....one more thing...
The new pump appears to have blade-type connectors, similar to the old pump. Can I assume that my two female connectors should go on the new pump in the same layout as the old one? (Black wire on left, red/white wire on right...I'll check my notes to be sure.)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Washer pump was clogged, now wont agitate bgreania Washer Repair 1 10-08-2011 09:43 AM
Washer won't drain, new pump, not clogged; brass pin found? MikeMc7734 Washer Repair 1 05-14-2011 11:32 AM
Washer works properly at times and stops between wash and spin/pump cycles at times sawgrassusa Washer Repair 0 02-26-2011 08:02 AM
new pump but ge washer still not draining wishiknew Washer Repair 0 12-04-2010 12:18 PM
Draining issue - don't think it's the pump paddle6 Dishwasher Repair 0 06-09-2009 12:44 PM
