| » whirlpool washer motor needs help to start |
Model Number: lsr8133hq0 Brand: Whirlpool Age: More than 10 years
motor hums when it tries to start. the compasator is cold, motor is hot or very warm,starup switch is cold. If I help the motor to start it will spin and do it's thing but at the next stage in cycle I have to help it along again. I took it out and cleaned it with electric motor spray no help. Is it the motor for sure or is the compasator weak to start the motor. What should I be replaceing. I just put a new clutch in it and working fine. pump is also new.
if you have an analog volt meter, you can test the cap ... most of the time, the motor should be replaced ... how old is the washer as at some point after replacing the pump , clutch ( coupler ) , replacing the washer becomes more cost efficient...
__________________
regards jim |
with an analog volt ohm meter, use a resistance setting as high as your meter allows... place leads on both terminals of the cap for @ 2 seconds or so, then reverse leads of your meter, if the needle jumps then your cap is good... ( you can also check each lead of the cap to the frame of the cap, as there should be no continuity from either lead to the housing of the cap.. ) dont forget, you have a start winding on your motor, you can determine from the wiring diagram which could be open or have too high a resistance value...
__________________
regards jim |
| Display Modes | |
| Washer motor will not run | den1 | Washer Repair | 0 | 12-13-2007 10:08 AM |
| Whirlpool motor | greene | Dryer Repair | 0 | 11-06-2007 03:11 PM |
| Whirlpool Dryer won't start | Conrad79 | Dryer Repair | 3 | 10-30-2007 08:54 AM |
| whirlpool gas dryer will not start | dmicare | Dryer Repair | 1 | 09-19-2007 07:16 PM |
| Dryer motor is noisey and sometimes humms and doesn't start | Tudeman | Dryer Repair | 2 | 07-20-2007 04:20 PM |
