renegade107
#1 Posted : Thursday, November 10, 2011 7:57:15 AM(UTC)
renegade107
My washer quit agitating a month ago and I replaced the Agitator. It worked for a month, now the Drive will not agitate at all. It sounds like it's working, but isn't. Everything else works on the washer. I don't know if it is timer, transmission or cogs. Can somene help be diagnose the problem? Thank You, Carla
:o
magician59
#2 Posted : Thursday, November 10, 2011 9:15:27 AM(UTC)
magician59
Here's a wiring diagram for your Atlantis model. Remove the agitator. Open up the control console and unplug the connector to the water level switch (that's the switch that has a rubber hose going from it down into the cabinet). Make a jumper (INSULATED) between the white and yellow wires in the connector, to simulate a full tub of water; and start the machine in a wash cycle.
If you don't see an agitating motion in the agitator drive shaft, the problem is inside the transmission.
Part number: AP4373431
renegade107
#3 Posted : Friday, November 11, 2011 3:55:26 AM(UTC)
renegade107
Thank you for your advise. I will try this when I get off work today. I will let you know the outcome.
Maytag washer will not agitate (Washer Repair)
by bobneedsadvice 6/25/2012 1:01:25 PM(UTC)
Maytag washer will not agitate or spin (Washer Repair)
by roscoepcoltrain 4/19/2012 4:55:32 AM(UTC)
Maytag Washer will not agitate or spin (Washer Repair)
by Mbat4 2/13/2012 3:12:24 PM(UTC)
Maytag washer will not agitate/cold water fill won't shut off (Washer Repair)
by denise2855 8/3/2010 2:14:09 PM(UTC)
Maytag Washer will not agitate but will spin and rinse (Washer Repair)
by pkbeckman 2/23/2009 7:56:44 AM(UTC)
