Discuss
Washer Fills and drains but won't agitate or spin.
 in
Washer Repair
My Whirlpool ThinTwin LT7100XVN0 will fill, then doesn't agitate (motor sounds like it's spinning), it drains, but doesn't spin. What's
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer Fills and drains but won't agitate or spin.
  #1 (permalink)
Old 11-09-2011, 10:48 AM
Junior Member
MADeane is on a distinguished road
Default Washer Fills and drains but won't agitate or spin.
Brand: Whirlpool   Age: More than 10 years
My Whirlpool ThinTwin LT7100XVN0 will fill, then doesn't agitate (motor sounds like it's spinning), it drains, but doesn't spin. What's up?
Ads By Google
  #2 (permalink)
Old 11-09-2011, 11:21 AM
Senior Expert
APP Volunteer
magician59 will become famous soon enough
Default
Pull the drain hose out of the stand pipe enough to give it an air gap.
  #3 (permalink)
Old 11-10-2011, 04:18 AM
Junior Member
Default
That will get the tub agitating and spinning?
  #4 (permalink)
Old 11-10-2011, 06:32 AM
Senior Expert
APP Volunteer
Default
It should...unless you have another problem. In order to fill, you need to have an air gap in the drain, or the water will siphon right back out. The agitagion cycle can't begin until the water level switch is satisfied, and signals the timer that it is full.
  #5 (permalink)
Old 11-10-2011, 01:11 PM
Member
dnlow is on a distinguished road
Default
I think it is the motor coupler. Search for videos on "Whirlpool coupler repair" and you should get a few. These will most likely be for topload washers, but the repair more or less will be the same. At least this will allow you to check if the coupler is bad.
Let us know what happens.
  #6 (permalink)
Old 11-10-2011, 01:17 PM
Senior Expert
APP Volunteer
Default
Quote:
After seeing your last post, I revisited your original post...I DON'T KNOW WHAT I WAS THINKING!
My response is consistent with a "...washer fills and drains at the same time..." complaint. My apologies. You're right It's either the lid switch, or the motor coupler. Look under the machine up front, in the center. If you see broken pieces of white plastic, or maybe even pulverized black rubber, it's the motor coupler.
Part number: AP3963893
  #7 (permalink)
Old 11-10-2011, 01:19 PM
Member
Default
Magician 59,
Everyone still knows you are the best around here!!!!
  #8 (permalink)
Old 11-11-2011, 08:08 AM
Junior Member
Default
Thanks for the info and video. I'm new to this sight and confused as to how to reply. Anyway, I will check this out later...I hope the cooupler is the problem. The twin machine is a bear to work on, or at least cumbersome. I had a heck of a time getting beyond the sheet metal...I may need a bodyshop to put it back together. I'll let you guys know as soon as I dig back into it.
thanks again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
GE Model WBSR1060 Fills, Drains, but only hum, no agitate or spin khaytsus Washer Repair 1 01-03-2011 12:49 PM
Maytag Will Not Spin or Agitate, Fills and Drains Only Maytag User Washer Repair 0 05-14-2010 11:32 AM
GE washer -fills & Drains, but will not spin or agitate tmacky34 Washer Repair 0 03-20-2010 05:54 AM
GE Washer fills/drains but won't spin/agitate sierrapup Washer Repair 1 03-07-2010 08:26 PM
GE fills and drains but doesn't agitate or spin ladytech Washer Repair 0 02-13-2009 02:11 PM
