I have a 7-8 year old Fridigaire washer that leaks after a completes wash cycle. I've looked inside while is working (lower front panel) and nothing drips until several hours later. The water appears from under the neath the machine. It's difinitely not the water connections in the back. Could it be the "tub bearing?
I found the answer myself. I took off the top and discovered the leak was coming from inside on the intake valve. The water was coming from there so which is what it was slow. $39 par5
