Discuss
Washer will agitate, but needs help spinning.
 in
Washer Repair
The washer will fill, agitate and drain, but when it is time to spin the clothes, I have to manually
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Washer will agitate, but needs help spinning.
Reply By reading any content on this site you agree to AppliancePartsPros.com, Inc. disclaimer and Terms of Use.
  #1 (permalink)
Old 12-14-2007, 03:54 PM
redi redi is offline
Junior Member
redi is on a distinguished road
Exclamation Washer will agitate, but needs help spinning.
Model Number: FWS445RFS3   Brand: Frigidaire   Age: 5 - 10 years
The washer will fill, agitate and drain, but when it is time to spin the clothes, I have to manually put my hand in the tub, and "force" it to go around, it feels like it is "stuck" on something. Once it is unstuck, and give it a little push, it picks up speed and starts to spin on its own.
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-14-2007, 04:56 PM
Gene's Avatar
Gene Gene is offline
Senior Expert
APP Volunteer
Gene has much to be proud of
Default
Remove the front panel and check the belt and the transmission pulley.
If there is nothing wrong then the transmission is bad and has to be replaced.
- The part number for the belt is AP3867042
- The part number for the transmission pulley is AP2107024
- The part number for the transmission is AP3892126
- Here are the break down diagrams for the Frigidaire washer Model FWS445RFS3
__________________
Professional appliance repair services in Orange County, California.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer not spinning rtzjackson Washer Repair 1 12-04-2007 07:22 PM
GE Washer: Not spinning or draining Vonnie2 Washer Repair 0 11-10-2007 09:54 PM
washer timer / not spinning pbush412 Washer Repair 0 09-05-2007 10:32 PM
washer stopped spinning leagleson Washer Repair 0 09-04-2007 10:18 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
