| » GE Washer won't drain |
Model Number: WHDSR315D5WW Brand: GE Age: 1 - 5 years
My washer all of a sudden yesterday would fill with water and wash my clothes but won't drain or spin.
I move the dial to the polsition where it should start the drain and spin cycle but it just humms...If I leave the washer on the dial rotates and starts agitating when it hits a certain spot on the dial otherwise it just has a slight humm until it gets to a position where it agitates. Any suggestions? Thank you! Ads By Google Related Models |
Remove the front panel. Check the lid switch. Check the pump motor. Remove the hoses from the pump and check them for a clog. Post the results.
Here are the breakdown diagrams and Replacement parts for GE WHDSR315D5WW | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
The lid switch has to be checked for continuity. The condition of the pump is visible as soon as you remove the front panel and run the washer on spin.
__________________
Where this "hum" is coming from?
__________________
A humming noise from the timer... sounds very unusual. It might be from the motor or from the drain pump.
Have you checked the lid switch for continuity? Have you checked the pump and its hoses? Gene.
__________________
You are welcome. We are glad you were able to fix it.
__________________
| Display Modes | |
| Washer does not drain | acer_620_u | Washer Repair | 1 | 12-09-2009 06:15 AM |
| washer does not drain | leh | Washer Repair | 0 | 08-22-2009 03:08 PM |
| Washer won't drain | aerrickson | Washer Repair | 2 | 05-17-2009 02:40 PM |
| GE Washer won't drain | Wannafix | Washer Repair | 0 | 06-12-2008 07:57 AM |
| Calypso Washer Washer Won't Drain | SamB | Washer Repair | 3 | 11-27-2007 01:41 PM |
