my washer fills and drains water without problem. but it doesn't agitate or spin. there's a clicking sound (two clicks every 2 seconds) even when it's off. i opened front panel, noticed green wire is cut. I reattached green wire (ground?) to the ground screw but it didn't fix the issue. any ideas what to check? thanks.
