I need to replace the timer knob and timer skirt on my maytag washer PAV2300AWW. Could you provide instructions?
Locate the hole with the timer knob shaft at the rear center of the timer. Using a small, flat blade screwdriver, pry the rod located in this hole up to release the timer knob. The knob and the skirt will then pull straight off. Here are the breakdown diagrams and Replacement parts for MAYTAG PAV2300AWW | AppliancePartsPros.comGene.
Thanks for your help Gene! Repair all done.
You are welcome. We are glad you were able to fix it.
