Discuss
fills, won't agitate or spin, motor runs, coupler ok
 in
Washer Repair
Washer fills, motor runs, but no agitation or spin with motor running. will drain. Was working for previous loads yesterday
Appliance Repair Forum > Appliance Repair Help > Washer Repair » fills, won't agitate or spin, motor runs, coupler ok
  #1 (permalink)
Old 11-07-2011, 03:59 PM
Junior Member
Lee H is on a distinguished road
Unhappy fills, won't agitate or spin, motor runs, coupler ok
Model Number: KAWS700GQ0   Brand: White-Westinghouse   Age: More than 10 years
Was working for previous loads yesterday and one or two today.
Presumed that the coupler was shot again. (One or more people have tried to wash too much leading to broken coupler pins! And they were doing wash again.) However, when I took it apart to replace coupler with the spares that I purchased last time I found that it was not broken this time.
Reassembled. No change:
Lid switch works, as the motor does run and washer drains only if lid closed while in drain/spin cycles.
Double checked connections for capacitor, motor multi connector, and two wire connector all in place, as was lid switch connector (actually forgot it the 2nd time but quickly noticed the problem). Can feel that coupler pins are still intact and in place.
BTW: The washer was purchased used over a year ago so I don't know how old the unit is. It replaced a Sears Kenmore model 110.20882990 (also purchased used about 8 years ago) before I found out about the coupler problems. I have already robbed parts from it (replace broken leveling spring and some other springs) since many of the part numbers are the same.
I noticed that the motor connector boards have the same part number, FSP 62850, and am thinking of switching the Sears one in if the motor part numbers and connector wiring match (have to take it apart again to verify). It's just that the old washer has been outside in the elements for over a year so there is a small amount of rust on the motor.
Anything else to try?
Related Models
Whirlpool KAWS700GQ0 AUTOMATIC WASHER
Whirlpool KAWS700GT0 AUTOMATIC WASHER
Whirlpool KAWS700GZ0 AUTOMATIC WASHER
Whirlpool KAWS700JQ0 RESIDENTIAL WASHER
Whirlpool KAWS700JQ1 RESIDENTIAL WASHERS
Whirlpool KAWS700JQ2 RESIDENTIAL WASHERS
Whirlpool KAWS700JQ3 RESIDENTIAL WASHER
Whirlpool KAWS700JQ4 RESIDENTIAL WASHERS
Whirlpool KAWS700JT0 RESIDENTIAL WASHER
Whirlpool KAWS700JT1 RESIDENTIAL WASHERS
Whirlpool KAWS700JT2 RESIDENTIAL WASHERS
Whirlpool KAWS700JT3 RESIDENTIAL WASHER
Whirlpool KAWS700JT4 RESIDENTIAL WASHERS
Whirlpool KAWS700LQ0 RESIDENTIAL WASHERS
Whirlpool KAWS700LT0 RESIDENTIAL WASHERS
Whirlpool KAWS750GQ0 AUTOMATIC WASHER
Whirlpool KAWS750GQ1 AUTOMATIC WASHER
Whirlpool KAWS750GT1 AUTOMATIC WASHER
Whirlpool KAWS750GZ0 AUTOMATIC WASHER
Whirlpool KAWS750GZ1 AUTOMATIC WASHER
Whirlpool KAWS750JQ0 RESIDENTIAL WASHERS
Whirlpool KAWS750JQ1 RESIDENTIAL WASHERS
Whirlpool KAWS750JQ2 RESIDENTIAL WASHERS
Whirlpool KAWS750JQ3 RESIDENTIAL WASHERS
Whirlpool KAWS750JQ4 RESIDENTIAL WASHERS
Whirlpool KAWS750JT0 RESIDENTIAL WASHERS
Whirlpool KAWS750JT1 RESIDENTIAL WASHERS
Whirlpool KAWS750JT2 RESIDENTIAL WASHERS
Whirlpool KAWS750JT3 RESIDENTIAL WASHERS
Whirlpool KAWS750JT4 RESIDENTIAL WASHERS
Whirlpool KAWS750LQ0 AUTOMATIC WASHER
Whirlpool KAWS750LQ1 AUTOMATIC WASHER
Whirlpool KAWS750LQ2 AUTOMATIC WASHER
Whirlpool KAWS750LQ3 AUTOMATIC WASHER
Whirlpool KAWS750LQ4 AUTOMATIC WASHER
Whirlpool KAWS750LT0 AUTOMATIC WASHER
Whirlpool KAWS750LT1 AUTOMATIC WASHER
Whirlpool KAWS750LT2 AUTOMATIC WASHER
Whirlpool KAWS750LT3 AUTOMATIC WASHER
Whirlpool KAWS750LT4 AUTOMATIC WASHER
Whirlpool KAWS777EQ0 DIRECT-DRIVE WASHER
Whirlpool KAWS777EZ0 DIRECT-DRIVE WASHER
Whirlpool KAWS800GQ0 AUTOMATIC WASHER
Whirlpool KAWS800GQ1 AUTOMATIC WASHER
Whirlpool KAWS800GZ0 AUTOMATIC WASHER
Whirlpool KAWS800GZ1 AUTOMATIC WASHER
Whirlpool KAWS850GQ0 AUTOMATIC WASHER
Whirlpool KAWS850GQ1 AUTOMATIC WASHER
Whirlpool KAWS850GT0 AUTOMATIC WASHER
Whirlpool KAWS850GT1 AUTOMATIC WASHER
Whirlpool KAWS850GZ0 AUTOMATIC WASHER
Whirlpool KAWS850GZ1 AUTOMATIC WASHER
Whirlpool KAWS850JQ0 AUTOMATIC WASHER
Whirlpool KAWS850JQ1 AUTOMATIC WASHER
Whirlpool KAWS850JQ2 AUTOMATIC WASHER
Whirlpool KAWS850JQ3 AUTOMATIC WASHER
Whirlpool KAWS850JQ4 AUTOMATIC WASHER
Whirlpool KAWS850JT0 AUTOMATIC WASHER
Whirlpool KAWS850JT1 AUTOMATIC WASHER
Whirlpool KAWS850JT2 AUTOMATIC WASHER
Whirlpool KAWS850JT3 AUTOMATIC WASHER
Whirlpool KAWS850JT4 AUTOMATIC WASHER
Whirlpool KAWS850LE0 AUTOMATIC WASHER
Whirlpool KAWS850LE1 AUTOMATIC WASHER
Whirlpool KAWS850LE2 AUTOMATIC WASHER
Whirlpool KAWS850LQ0 AUTOMATIC WASHER
Whirlpool KAWS850LQ1 AUTOMATIC WASHER
Whirlpool KAWS850LQ2 AUTOMATIC WASHER
Whirlpool KAWS850LT0 AUTOMATIC WASHER
Whirlpool KAWS850LT1 AUTOMATIC WASHER
Whirlpool KAWS850LT2 AUTOMATIC WASHER
Whirlpool KAWS855JE0 WASHER
Whirlpool KAWS855JE1 WASHER
Whirlpool KAWS855JE2 WASHER
Whirlpool KAWS855JE3 WASHER
Whirlpool KAWS855JE4 WASHER
Whirlpool KAWS977EQ0
Whirlpool KAWS977EZ0
Bosch KB030-062
Bosch KB032-062
Bosch KB035-062
Bosch KB036-062
Bosch KB090-054
Bosch KB091-054
Bosch KB100-046
Frigidaire KB122G0 Wwh(v1) / Built - in Oven
Frigidaire KB122G1 Wwh(v2) / Built - in Oven
Frigidaire KB122G2 Wwh(v3) / Built - in Oven
Frigidaire KB122G3 Wwh(v4) / Built - in Oven
Frigidaire KB122G4 Wwh(v5) / Built - in Oven
Frigidaire KB122LM0 Wwh(v1) / Wall Oven
Frigidaire KB122LM1 Wwh(v2) / Wall Oven
Frigidaire KB122LM2 Wwh(v1) / Wall Oven
Frigidaire KB122LMO Wwh(v1) / Wall Oven
Frigidaire KB152LM0 Wwh(v1) / Electric Range
Frigidaire KB152LM1 Wwh(v1) / Electric Range
Frigidaire KB152LM2 Wwh(v1) / Electric Range
Whirlpool KB26G1X-3 6 QT. STAND MIXER
Whirlpool KB26G1XAC3 6 QT. STAND MIXER
Whirlpool KB26G1XAC5 6 QT. STAND MIXER
Whirlpool KB26G1XBU3 6 QT. STAND MIXER
Whirlpool KB26G1XBU5 6 QT. STAND MIXER
Whirlpool KB26G1XER3 6 QT. STAND MIXER
Whirlpool KB26G1XER5 6 QT. STAND MIXER
Whirlpool KB26G1XGN3 6 QT. STAND MIXER
Whirlpool KB26G1XGR3 6 QT. STAND MIXER
Whirlpool KB26G1XGR5 6 QT. STAND MIXER
Whirlpool KB26G1XMC3 6 QT. STAND MIXER
Whirlpool KB26G1XMC5 6 QT. STAND MIXER
Whirlpool KB26G1XMY3 6 QT. STAND MIXER
Whirlpool KB26G1XMY5 6 QT. STAND MIXER
Whirlpool KB26G1XOB3 6 QT. STAND MIXER
Whirlpool KB26G1XOB5 6 QT. STAND MIXER
Whirlpool KB26G1XPT3 6 QT. STAND MIXER
Whirlpool KB26G1XPT5 6 QT. STAND MIXER
Whirlpool KB26G1XTG3 6 QT. STAND MIXER
Whirlpool KB26G1XTG5 6 QT. STAND MIXER
Whirlpool KB26G1XWW3 6 QT. STAND MIXER
Whirlpool KB26G1XWW5 6 QT. STAND MIXER
Frigidaire KB443GDM0 Wwh(v1) / Electric Continuous Clean Oven
  #2 (permalink)
Old 11-09-2011, 07:37 PM
Senior Expert
APP Volunteer
sidfink43 is a jewel in the rough
Default
If the motor is turning but there is no agitation or spinning then that suggests the transmission is the problem. See if you can determine if the one in your parts machine is compatible with your newer machine, and if so, change it out and see if that fixes things.
Check the coupling again before you do anyting, sometimes it can have hairline cracks in the plastic pieces that are difficult to see.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
kenmore 90 seriers, no spin or agitate and coupler is not broken junkyard44 Washer Repair 1 02-28-2011 07:34 AM
Bosch SHU5306 drain motor runs, never fills RA3Goat Dishwasher Repair 0 01-12-2011 07:58 PM
motor runs but wont agitate or spin james crawford Washer Repair 1 12-02-2009 07:37 AM
No spin or agitate-coupler OK corymaag Washer Repair 1 08-26-2009 06:27 AM
Ice dispenser auger motor runs, doesn't turn coupler dublegle Refrigerator & Freezer Repair 1 08-03-2009 05:31 PM
