Discuss
Help!! Washer Want Drain Or Spin
 in
Washer Repair
WASHER WILL RUN THROUGH WASHING CYCLE. WHEN IT GOES TO DRAIN CYCLE IT CUTS OFF. THE MOTOR IS NOT RUNNING &
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Help!! Washer Want Drain Or Spin
  #1 (permalink)
Old 12-13-2007, 06:19 PM
rpearce rpearce is offline
Junior Member
rpearce is on a distinguished road
Default Help!! Washer Want Drain Or Spin
Model Number: LSQ9010LW0   Brand: Whirlpool   Age: 1 - 5 years
CYCLE IT CUTS OFF. THE MOTOR IS NOT RUNNING & I HAVE CHECKED THE PUMP & DRAIN LINES. I DIDN'T FIND ANYTHING WRONG . COULD IT BE THE TIMER OR CONTROL BOARD
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 12-13-2007, 07:25 PM
abbie abbie is offline
Senior Expert
APP Volunteer
abbie is on a distinguished road
Default
First thing I would check is the lid switch or the strike on the lid that fits in the hole in the cabinet THE SWITCH SHOULD MAKE A CLICKING NOISE WHEN YOU TEST IT.
__________________
  #3 (permalink)
Old 12-14-2007, 04:37 PM
Junior Member
Default
I checked it everything is o.k. with the lid switch? Do you have any other suggestions .
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
washer will not spin or drain Martha Shelby Washer Repair 2 10-25-2007 03:43 AM
washer will not spin or drain Martha Shelby Washer Repair 1 10-24-2007 04:59 AM
Washer wont spin/drain AndreaB Washer Repair 0 10-12-2007 05:27 PM
Washer won't drain or spin carrol Washer Repair 2 08-20-2007 07:37 AM
Washer will spin slowly but not drain Mikie Martin Washer Repair 0 07-31-2007 08:36 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
