Discuss
Mah5500bww
 in
Washer Repair
I need help on how to remove the top cover on this washer. Everything is loose except the front corner
Appliance Repair Forum > Appliance Repair Help > Washer Repair » Mah5500bww
  #1 (permalink)
Old 11-06-2011, 03:54 PM
PTB PTB is offline
Junior Member
PTB is on a distinguished road
Default Mah5500bww
Brand: Maytag   Age: More than 10 years
I need help on how to remove the top cover on this washer. Everything is loose except the front corner areas. I need to remove the front panel and front shroud, too, so that I can change out the boot. Your help with this info will be greatly appreciated. Thanks.
Ads By Google
  #2 (permalink)
Old 11-06-2011, 09:42 PM
PTB PTB is offline
Junior Member
Thumbs up
I figured out the issue, so there is no need to respond. Thanks.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Maytag MAH5500BWW tub bearing issue aulrich1 Washer Repair 1 03-29-2012 04:05 PM
maytag mah5500bww kampat Washer Repair 3 09-15-2011 06:29 PM
Neptune MAH5500BWW extremely loud home4sale2 Dishwasher Repair 0 04-22-2009 04:56 PM
Neptune MAH5500BWW burned control board fred973 Washer Repair 2 04-18-2008 02:18 PM
Maytag Neptune Washer model # mah5500bww Scotty Washer Repair 1 10-22-2007 04:29 PM
